Old 06-17-2018, 07:14 PM   #1
sjvaught's Avatar
Leak from water pump
We have a 2016 Forester 3051 and under the pump water is constantly leaking. I’ve taken plastic filter holder off and put back on but still leaks. Could I order a new filter?
sjvaught is offline   Reply With Quote
Old 06-17-2018, 08:06 PM   #2
Duckogram's Avatar
Do you know where the leak is coming from? You ellude that it is coming from the pump then you jump to the filter. ( must assume you mean housing).
From there, I must ask if you lubricated the housing bowl o-ring. If the answer us no, I suggest you start there.
Unless you are calling the strainer a filter. Then we are in a different ball park.
ILB
Old 06-17-2018, 08:20 PM   #3
sjvaught's Avatar
Yes it is the clear plastic round container holding the metal filter
Old 06-17-2018, 08:28 PM   #4
Duckogram's Avatar
Ahh, the strainer is leaking. Check for cracks and the condition of the gasket.
Those critters are about $10 to replace the entire assembly. Even WallyMart has them. Post a photo so the correct one can be identified.
Edit: or use this link: http://shurflo.com/rv-products/rv-ac...s/rv-strainers
ILB
Old 06-17-2018, 08:38 PM   #5
Flybob's Avatar
If the TT was winterized with compressed air only and no antifreeze via a winterizing port, then it is possible that the small amount of water that remains in the strainer could freeze and crack it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-18-2018, 01:03 PM   #6
sjvaught's Avatar
pump strainer
Here pictures of my strainer, is this a barbed connector?
ID:	176362   Click image for larger version
Old 06-18-2018, 01:18 PM   #7
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
First, check the connections on either side of the strainer by hand, do not use pliers. If you know it is the strainer that's leaking don't mess around install a new one, again no tools. A small drop of dish soap on the threads and o-ring makes it easier to tighten without running the risk of damaging the o-ring.
I have one of those water alarms from HD under the pump, under the sink, washing machine, etc. to catch leaks before they become a problem.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 06-18-2018, 01:32 PM   #8
Duckogram's Avatar
I cannot tell from your photo as it only reveals one connector. The one I can see looks like a twist on side. The barb portion is part of the female connector that the strainer would thread into.
If the hidden side has a swivel nut, life just got real simple.
Edit: For clarity, the swivel nut would be part of the strainer body and not part of a connector crimped into the hose.
ILB
leak, pump, water, water pump
