Old 05-12-2016, 11:01 AM   #11
2 years ago when blowing out the trailer, I forgot to reduce the pressure from my compressor and accidentally hooked up with 125psi, rather than closer to 60psi. I didn't have any damage other than the valve of the toilet was the first thing to blow and shoot water everywhere. Had to pull the toilet, order the new valve ($25 I believe), replace and reinstall. Wasn't too bad, but what a big mistake I'll never make again.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 05-12-2016, 11:27 AM   #12
Originally Posted by youroo View Post
You have me confused, did the problem fix itself? Youroo!!
OP was clarifying a typo in the first sentence of the first post, which I have fixed now.
Iwritecode is offline   Reply With Quote
Old 05-12-2016, 11:34 AM   #13
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Those water leaks can be annoying...and coming from where you least likely think it's coming from.
2x with ependydad... we too had a toilet leak from a cracked valve...even thought we had winterized.....you could not see cracked valve. That pesky leak would come and go. Tooks us months to figure it out.
Good luck finding and fixing yours.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 05-12-2016, 04:26 PM   #14
Originally Posted by suscamper View Post
Also water pump is on other side of RV and not in use was we are on city water.
Just leaks when under pressure which is why we turned off city water for now
Go to a repair shop and have them hook up 50PSI AIR to the City Water supply! That will allow you and them to "HEAR" where the Leak is located without the "Water Mess"! Youroo!!
Old 05-13-2016, 10:49 AM   #15
In my case it's twice been the seals in the flex connection. Both time went to the hardware store and replaced the rubber seal.
Caution: do not over tighten the fitting.
Las Cruces is offline   Reply With Quote
2501, leak
