Old 05-12-2016, 09:34 AM   #1
Leak in our 2501TS behind toilet - URGENT
We have camped since dewinterizng with no problems.
Left this week and found that when we turned on the water pump hooked up to city water we got a leak. It stops when we turn off the water. It drips in in from the rear of the back drivers side wheel well and back toward the storage compartment.
We are just started a 2 week camping trip and keeping the water off.
Trying to get a local mobile RV repair guy out. (Have platinum insurance broker a $500 deductible and our RV is 14 months old so the original warranty is done)
Any ideas how big an issue this might be and if we are wasting time and $ getting this guy to look at it. Hoping maybe a loose connection from the drive here? Is there a plumbing diagram that would help nail it down?
Suz
suscamper is offline   Reply With Quote
Old 05-12-2016, 09:34 AM   #2
Correction. No problems after dewinterizng.
Old 05-12-2016, 09:36 AM   #3
PS. our toilet in the camper where the leak is. It's definitely fresh water leaking
Old 05-12-2016, 09:44 AM   #4
Is it pex tubing? If so look for loose/bad crimp. Check the little clear filter on the water pump because it might have a crack in it. Just things that have failed on my past campers.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=26
Electra glide is offline   Reply With Quote
Old 05-12-2016, 09:45 AM   #5
You have me confused, did the problem fix itself? Youroo!!
Old 05-12-2016, 10:01 AM   #6
Will explain again. Just to clarify. Leak still there. We are camping with water turned off. Back of toilet faces the wall where the leak is located
Old 05-12-2016, 10:04 AM   #7
Also water pump is on other side of RV and not in use was we are on city water.
Just leaks when under pressure which is why we turned off city water for now
Old 05-12-2016, 10:05 AM   #8
Fulltime family RVer
I've dealt with 3 different toilet leaks:
- 2 of them were because my water valve broke due to improper winterization
- 1 of them was just last week and it was the hose that connects to the water valve- just needed a little tightening
You're going to need to get down in there and find where the leak is specifically coming from. I take toilet paper and wrap it around different connection points. Whichever is wet tells you where the leak is coming from. Then you can start to attack the problem.
And, what make/model of toilet is it?
Old 05-12-2016, 10:09 AM   #9
There is no leak by toilet inside.
Just an FYI for orientation the leak is outside near where the toilet is located
Old 05-12-2016, 10:16 AM   #10
I see, I misunderstood. I've also dealt with a variety of other leaks. The most common is where flexible lines are cinch clamped to hard lines. In 3 different cases, I've had to cut the old cinch clamp off and replace with with a hose clamp with a screw. In the other case, it was an issue with my water heater leaking.
No matter what, you have to follow the water to the source. It's a real pain in the butt to do sometimes, though. What water fixtures are around the area that it's leaking? It could be a line feeding the toilet.
Often times you can remove panels from walls/cabinets in order to get a better look.
2501, leak
