Old 06-24-2014, 03:44 PM   #1
Phat Phrog Stunt Crew
elind's Avatar
Leaking gray water
I have a new Wildcat and every time I open the drain cap to dump it I get a cup or two of gray water. I thought maybe a drain valve wasn't closing all the way or a bad valve. I called the dealer for service on this and they said this was "normal". That water lays in the pipes and when it moves it works out to the drain cap. Is the normal? Should just put a valve gate at the end of the drain and call it quits?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 06-24-2014, 03:58 PM   #2
TURBS's Avatar
The seals could be a little dry elind.
Try putting a gallon or more of water in your grey tank after dumping.
Don't leave "any" of your tanks completely dry between trips.
Old 06-24-2014, 04:09 PM   #3
elind's Avatar
I'll try that because the 5er sat empty tanks for a year before we put it into use. My dealer seems to try hard but some of their answers . One was the story that using a gas refer when traveling is ILLEGAL in Michigan.
2014 Wildcat 327ck
Old 06-24-2014, 04:15 PM   #4
Put another valve on the end and a clear elbow and then the cap. That way you can see what is waiting on you.
Old 06-24-2014, 05:05 PM   #5
elind's Avatar
OC, That was plan B for me. I've the clear 45 elbow already and pickup the valve Friday when I go in for service. Gray water isn't too bad but black water......NO WAY.
2014 Wildcat 327ck
Old 06-25-2014, 09:21 PM   #6
Boss Ox & Drovergirl
oxcamper's Avatar
I don't know about being Illegal in MI, but leaving the gas on for the refridgerator while travelling certainly is a major hazard when stopping to fuel up. Many travel stops I've been to have signage to turn off all LP gas at the bottle before filling up with gas. The heat and open flame can ignite gasoline fumes.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 07-11-2014, 05:00 AM   #7
arpipeliner's Avatar
Name:	ImageUploadedByForest River Forums1405072700.564335.jpg
Name:	ImageUploadedByForest River Forums1405072719.208055.jpg
Saw this a camper place getting parts for hot water heater. Remembered this thread and mine has done it once maybe twice. But this would be my route.
arpipeliner is offline   Reply With Quote
Old 07-11-2014, 05:40 AM   #8
hrlyguy2's Avatar
Mine did that aswell.Took it too the rv shop and they had to take my under belly off and replace the valve.
Fixed that one .
Now my galley valve is doing it .
Always something !!!!
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 07-11-2014, 06:36 AM   #9
Here we Go agin? Turning off the Propane will NOT stop his Gray Water Issue! Youroo!!
Old 07-11-2014, 07:05 AM   #10
You are lucky it's the gray water, I have the same problem with the black. It's on a new 27rr. I have had the same problem on a couple of other campers but not when new.
comfun1 is offline   Reply With Quote
leak, water
