Originally Posted by KenHwy61
They leak because the braided white tubing was never designed to go on PEX fittings. The ID of the braided tubing is too large for a tight fit on PEX fittings.
Exactly. To my knowledge there is no fitting made that is pex/barbed. They would have to use pex to threaded and then threaded to barbed.
Since they have a hard enough time getting any connections not to leak, adding more into the mix is most likely not a good idea.
Its just plumbing done by Shoemakers. Carry lots of clamps.
