Old 12-31-2018, 07:27 PM   #1
Unhappy Leaking Issue
Hi, I have a small 19 foot Wildwood Xlite Travel Trailer. I'm experiencing a leak from my fresh water pipes that are located down behind the cabinet area. There is water build up on the floor and it will leak with the pump on. I can see the pipes from the small access below the shower, but I can not reach them from there. It's also not accessible from under the sink area, and I've tried to find access underneath the rig from the outside. I can't seem to find a way to get to them, maybe I'm missing something. If anyone knows how to access them or has any info. that might help, it would be super appreciated!
AstraDoch is offline   Reply With Quote
Old 01-01-2019, 12:53 AM   #2
cavie's Avatar
You may get the info your looking for if you post on the Wildwood form and add some pictures.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
leak
