Old 02-27-2014, 11:32 PM   #1
Leaking pipe
On my new trailer I have a leaking fitting. I have contacted the salesman, but wanted to see if any one had any fixes here. It appears the leak is on the fitting between the plastic tubing and male connector for the hot water.
2009 Chevy Silverado 5.3L Z71
2014 Salem 281QB
tmas is offline   Reply With Quote
Old 02-27-2014, 11:49 PM   #2
iceblaze580's Avatar
I would go to Home Depot and see if they have a shark bite fitting that has the male thread cut the old one out and replace with the shark bite fitting
iceblaze580 is offline   Reply With Quote
Old 02-28-2014, 12:01 AM   #3
keith4216's Avatar
or get rid of the pinch clamp and use a real hose clamp.
keith4216 is offline   Reply With Quote
Old 03-01-2014, 07:22 PM   #4
X2
okietom is offline   Reply With Quote
Old 03-01-2014, 07:30 PM   #5
Also make sure the fitting is tight.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 03-01-2014, 07:41 PM   #6
Twisty's Avatar
Did you get it repaired?
Curious about what was wrong.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 03-01-2014, 08:11 PM   #7
kz08h5's Avatar
It looks to like the fitting attached to the red PEX has a problem. I see water between the PEX and the fitting. Based on the amount of deflection with the red PEX vs the blue PEX I bet the plastic fitting is cracked. PEX crimping tools need to be calibrated. Both the pinch clamp and the crimp type tools need this. From my internet research pinch clamps are just as good as crimp clamps. I would not use a regular hose clamp for the repair. I wouldn't think you could get enough clamping force with one.
Let us know how things work out.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 03-01-2014, 10:29 PM   #8
schaferk's Avatar
I second the shark bite fotting
schaferk is offline   Reply With Quote
Old 03-01-2014, 11:25 PM   #9
Is it still under warranty if so make the dealer do it
leak
