I assume it is the toilet that's leaking and not the freshwater inlet or valve assembly.
We had a similar problem a few years ago, I disconnected the water and removed the complete toilet from the trailer to do the messy work outside. when you lift the toilet have someone slide a large garbage bag over the base to catch water still sitting under the bowl. Once outside, separate the bowl from the base, clean everything, replace or clean and lubricate the seal, bolt the two halves back together, place it on a new floor seal on top of the sewer pipe in the bathroom, tighten it to the floor, done.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
