If you are referring to the interface of the shower walls to the shower floor pan, you should not need to caulk that, There is a lip on the shower floor behind the wall that should be higher than the bottom of the shower wall.
You can also add a few wood spacers between the shower floor and the RV floor to keep the floor from flexing too much.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
