Lighted Switches
I have a 2014 Georgetown 351ds. Because DW and I both have problems determining when a Command Center switch is on, I decided to replace the rocker switches with lighted switches that would be lighted when the switch is on. I purchased some switches from an auto parts place and tried to replace the ones on the Command Center but immediately ran into a problem. I blew several fuses and the switches don't work. Apparently tab 3 on the ones installed for the water pump and Arctic Pak is isolated. On the ones I purchased, tab 3 is active when the switch is in the off position. What do I need to have a lighted switch that works and doesn't blow fuses?
SlowJoe
2016 Jayco Red Hawk 23XM
