Old 03-26-2016, 10:36 AM   #1
Locating Low-Water points on 2000 Sandpiper Fiver
I have a new-to-me 2000 Sandpiper - my first TT - and I'm familiarizing myself with the whole system. I've been unable to find the low-water drain points. All I've found is the fresh water tank drain. Anyone with any insight?
Thanks in advance,
BP
bwp98h is offline   Reply With Quote
Old 03-26-2016, 10:41 AM   #2
Ford Idaho's Avatar
Have you looked inside any bench seating your unit has?
You may need to remove a screw or four.
Pull the cushions, board may just pull out or screwed down.
Old 03-26-2016, 10:52 AM   #3
Thank you for taking the time to reply! The only built-in seating my unit has is in the slide-out and I don't see any plumbing components under there.
Old 03-26-2016, 11:02 AM   #4
Ford Idaho's Avatar
Is the slide on the street side?
If so look underneath just in front of the slide about 4 inches in from the side of the wall.
Was there an overflow tube near the FW drain?
Old 03-26-2016, 12:04 PM   #5
Oakman's Avatar
Look under the trailer between the frame and the skirting. You may even have to look up since the drains may not stick down very far.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
cat, sandpiper, water
