Old 08-13-2015, 12:50 PM   #1
Look what came out of my gray water tank
We bought our 2011 Rockwood Roo last year and the past few times we've tried to dump the gray water tank, it would drain very slowly. We thought maybe the handle came apart from the slide that allows the tank to drain. I took it apart last weekend and was astonished at what I found. This is shredded plastic and couldn't of gotten in there thru the sinks or tub. Anyone have an ideas?? Leftover from the mold at the factory?? Finally dislodged after all these years?? Crazy!!!!
ID:	85521   Click image for larger version
ID:	85522   Click image for larger version
abewitched1 is offline   Reply With Quote
Old 08-13-2015, 01:05 PM   #2
dannyabear's Avatar
That is from when they drilled the holes into the tank; looks like the shavings from a hole saw.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 08-13-2015, 01:12 PM   #3
Evereddie's Avatar
Looks like the elusive 'fiberglass spider' built a nest in there. :-)
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 08-13-2015, 01:27 PM   #4
Danny, is it normal they would leave them in there??
Evereddie: HAHAHAHA....that was funny.
Old 08-13-2015, 01:44 PM   #5
Scubanut's Avatar
I believe it is a normal part of assembling the tanks. They drill a hole and the plastic falls into the tank and either floats around or is drained. I had a pretty big chunk of plastic come out my tank. Normally you wouldn't notice because it would go into camp ground septic tank. I noticed mine when it was new I used the sink and other drains and dumped it on the ground. Clean water "only". That is how I noticed the plastic.
2012 F150 FX4 Crew 5.0
2012 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 08-13-2015, 01:53 PM   #6
Wonder why it didn't come out with the previous owners? The trailer is 4 years old. lol. Lucky us
Old 08-13-2015, 02:10 PM   #7
Evereddie's Avatar
Most gray tanks I know about and have seen have a smaller drain tube on the gray than the black tank. That limits the size of stuff that gets easily drained. Since there is suppose to be nothing bigger than a kernel of corn in the gray tank it's not an issue having a smaller drain pipe. I did read somewhere on this message forum of a guy who do a mod to his gray tank to make the drain as big as the black tank. Wanted a quicker drain and get away.
Old 08-13-2015, 02:27 PM   #8
Good point Evereddie. Wondering why they'd leave those fairly large pieces of plastic in there?? Grey tank tube is pretty small and I had to pull that mess out with needle nose pliers. I think in my case they left way too much and there was no way it was coming out on it's own.
Old 08-13-2015, 03:23 PM   #9
DaveSchwartz's Avatar
Just too lazy to fish it out. People have had the entire plastic disk cut out by the hole saw blocking up the drain too. If the disk falls off the hole saw before it comes back out it seems sometimes they just look the other way.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 08-14-2015, 04:04 PM   #10
Lazy workmanship. Had the same thing happen to me.
Racer310 is offline   Reply With Quote
Old 08-14-2015, 04:13 PM   #11
Lazy, sloppy, pathetic and typical FR manufacturing standards. Did I mention FR is on my ****list today? Sure wish I could give Warren Buffet a piece of my mind.
phillyg is offline   Reply With Quote
Old 08-14-2015, 04:22 PM   #12
Broadway Joe's Avatar
Playing devils advocate: if you were drilling the tank, how would you remove the drillings?
Broadway Joe is offline   Reply With Quote
Old 08-14-2015, 04:40 PM   #13
The same way FR does when drilling 35 of them a day.
Old 08-14-2015, 04:44 PM   #14
Suck it out with a high powered shop vac?? I'm sure they drill a lot of holes: the sink, the tub, the vents, etc Most manufacturers don't leave the shavings just laying where they fall though. Normally it wouldn't be a big deal except it caused us a lot of hassle when we couldn't drain our grey water. Then when we got home, it did drain so we thought we were good. Next trip same thing so it was really annoying.
Old 08-14-2015, 04:47 PM   #15
Have any of you retrieved one of the 3" disks left behind? I saw one floating around in my black tank, chased it around for a while with a modified marshmallow fork to no avail... Gave up, but I would like to get it out of there before it plugs up the drain pipe. Any suggestions???
TL474 is offline   Reply With Quote
Old 08-14-2015, 05:01 PM   #16
Ford Idaho's Avatar
http://www.amazon.com/gp/product/B00...d_i=B002S47WWK
Old 08-14-2015, 05:09 PM   #17
TL474 Maybe one of those long grabber arms if you can find one with a small enough claw?? Try it with an empty tank if you can see it or a tank full of water.
Old 08-14-2015, 05:11 PM   #18
schrederman's Avatar
I saw this in my black tank and made a wire hook. Poked it through the pilot hole in the center and got it out that way... not fun. Once I got it up there it wouldn't come through the toilet opening easily. I was afraid I was going to do more damage than I wanted to fix. So I had to get a pair of pliers and some snips, and cut one side off. Yes, I dropped it a couple of times... Yep... I was cussin' FR that day. Not sure how many times I washed my hands that evening... but the tan on my hands didn't match my arms...
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 08-14-2015, 07:11 PM   #19
Good idea, but MY toilet isn't as big as a FordIdaho! Thanks
Old 08-14-2015, 07:13 PM   #20
That was what I was trying to do but got tired. At least I know it can be done! Thanks
tank, water, water tank
