Old 07-02-2013, 08:26 PM   #1
Lookin for good water pump
Looking to upgrade my fresh water pump to a variable speed type, non pressure switch, non pulsing type pump. Anyone have any good experiences.
Enaud-c is offline   Reply With Quote
Old 07-02-2013, 08:32 PM   #2
If the pump doesn't have a pressure switch, what turns it on?
bakken is offline   Reply With Quote
Old 07-02-2013, 08:46 PM   #3
Here is a description for one I found. "Flojet's unique Variable Speed Drive system needs no pressure switch. Its microprocessor provides precise speed control to match the system demand. As more water is needed, the motor drives the pump for more flow. As the demand lessens, the motor slows to a super-quiet speed, yet maintains a steady pressure. The result is an unbelievably home-like flow. This smooth performance from no flow to maximum flow is sensor controlled, without any cycling - so an accumulator tank is not needed. The system is free of pulsation, water hammer and temperature swings. Amp draw reduces as flow reduces to conserve energy, ranging from less than 1 amp to a max.of 10 amps"
Old 07-02-2013, 09:07 PM   #4
Witch Doctor's Avatar
I would check the area and dimensions first, some will not fit in the area where yours is now, are you talking about the one with the belt drive? those are a lot bigger. Measure twice and buy once. Good idea through, and good luck with your install.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
