09-03-2018, 09:40 AM
Looking for short sewer hose
I'm looking for a SHORT sewer hose, around 6 feet maybe. I don't want a Rhino. Had nothing but bad luck with those. I have Valterra Viper now, and if I'm a long way from sewer connection, I'm great. But if close, I have to 'meander' with curves and turns. It'd be nice to have a short hose for those times (like THIS campsite I'm in!!) when sewer port is close.
Can't find one! Every ad is for how LONG they are!
Anyone??
FROG AR-0019-242
09-03-2018, 09:46 AM
I searched for 5' rv sewer hose and found several. I have a 5' Rhino hose and it's been good so far. But I understand if you've had problems with them you not wanting them again.
Gotta go campin!
09-03-2018, 09:48 AM
I have a 2 ft. collapsible one I use to get out of my compartment. You could use a couple of them together. Twist on like the cap on the unit. I believe its valtera.
I have 2 of them and use a clear flush out that I put a gate on. Reaches almost 5 ft.
09-03-2018, 09:55 AM
I have Never seen a sewer hose Ad bragging about how Short it can be used! To bad you don't like Rhino hose, they are easy to Shorten and simply screw in and Lock! Youroo! !
09-03-2018, 10:01 AM
Denver To Yuma In 90 Days
I have the black 'Rhino' hoses and love them.
I saw the 5', 10' and 20' Rhino hoses at both Walmart and Camping World if you need to get them quickly.
I had 40 ' of the red 'EZ Coupler' hose setup before and it was OK, but they always leaked a little.
I finally tossed them out a recently as I moved them to back-up status after purchasing the Rhino and using it for a couple of months.
I have 35' of Rhino...gonna get at least one more 10-footer to give me a little more reach.
09-03-2018, 10:06 AM
I found a 2 foot one for Viper. I had Rhino, two of them, and they developed a LOT of pinholes. The Valterra Viper is 10X stronger, it seems to me, and mine have lasted years, and through LOTS of ins and outs. Just had good luck.
I think A32 has the best answer. Maybe get 1,2, or 3 of these:
https://www.etrailer.com/p-D04-0402.html
and use however many together as needed.
Just don't see a GOOD 6' foot hose anywhere, so that's probably my best bet.
FROG AR-0019-242
09-03-2018, 12:28 PM
Many have ends that come off and you can shorten a hose.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
09-03-2018, 12:30 PM
You can shorten Rhino hoses easily.
24WS
FX4 Off Road (4X4)
09-03-2018, 01:27 PM
I too was looking for a shorter sewer hose. The longer ones are great for full hookups but not so good at the dump station. I just this week bought a Camco 10 ft hose. It's actually two 5 ft hoses connected. It also has a 90° elbow.
Haven't used it yet...going out this weekend.
BTW. Got it at WM.
Jim and Deb
Many times..asst grandkids
2015 Shamrock 23ikss
2013 Ram 1500
09-03-2018, 01:36 PM
I've had good results with the blue line brand for quite a few years. I have a 5 footer and what pieces I need for fhu
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
09-03-2018, 01:45 PM
Anyone??
Buy a long one, two new end connectors and you will have TWO short hoses.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-03-2018, 01:53 PM
Anyone??
I bought and use:
Valterra D04-0112 EZ Coupler 5' Extension Hose .
I use it when I have a short run.
09-03-2018, 02:48 PM
The only other issue with the EZ Connector brand and the Rhino hoses is that they don't fit into the rear bumper storage space.
09-03-2018, 03:24 PM
Wait...what? TOO SHORT?
Anyone??
I thought those darned things were ALWAYS too short no matter how LONG I buy them? Guess I'd better revise my parking strategies!
Si Hoc Legere Scis, Nimium Eruditionis Habes!
09-03-2018, 05:14 PM
I have a 10’ Rhinoflex sewer hose. It collapses to about 3.5’, I thought the Valterras do the same? And they do fit in my bumper.
09-03-2018, 05:15 PM
Two for us
BTW. Got it at WM.
The 2007 Cherokee 38P is permanently sited at a resort with no sewer hookups. We have a simple hose with bayonet connectors on both ends that started out at about six feet long. It's used to transfer from the tanks to the Blueboy. As the hose internal wire coils rust and it begins to drip, I cut off 5-6" and re-attach the ends. It's under four feet now and I expect to keep using it until it's less than two feet long.
We need a different hose at the dump station. The dump station connections are female-threaded 4" PVC and we are expected to connect to them. The connection is in the middle of a 3 foot square concrete pad which is steeply pitched (maybe 3") toward the center.
I bought a CAMCO 39551 and I have been looking for a chance to warn others away from it. If I could give it minus 5 stars, I would. I don't think anyone at CAMCO has actually tried this unit.
The first problem is that the design doesn't consider that the threaded connection is PVC-to-PVC and hence prone to seize. When you thread it in to a 4" connection and it seizes, there's nothing to grab onto to unscrew it. The amount of pipe protruding is only enough to pinch with thumb and index finger. You can't wrap your hand around it.
So you put the elbow and hose onto it to try to start it moving--and the four tiny, little bayonet nubs immediately shear off. (I drilled and tapped to replace them with four 8-32 round-head stainless steel screws, permanently attaching the adapter to the elbow.)
The third problem is the worst. Because the adapter is too short, when I attempt to screw it into the dump station connector, I can only thread it in about 1-1/2 turns. Before long, the hose is scraped through just before it attaches to the elbow, from abrasion on the dished concrete surface. The hose (also much longer than it needs to be) coils had already rusted most of the way through when I cut off the leaky portion last week, and it's only 2-3 years old. This is just not a quality product.
While I was typing this I realized that I could resolve this problem by adding a 4" "riser extender" to the adapter to lift the threaded portion of the elbow about the connector. Unfortunately no one makes one. I also considered a 4" MIPS to 3" FIPS reducer bushing, but the only one I could find costs $250 for a five-pack.
Larry
09-03-2018, 05:41 PM
Location: Alberta - East of the Rockies, West of the Rest
https://www.lci1.com/waste-master
It stays put where the Rhino hose and others don't.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
09-03-2018, 08:44 PM
I actually gave away a brand new Rhino hose because it was slightly too big in diameter for my sewer connection which caused a loose seal. I've never bought another Rhino hose again.
I actually carry six sections of sewer hoses. The main one has permanent ends on it but the rest all have screw on ends to either extend or shorten.
It's like TP, you can never have enough.
09-04-2018, 07:09 AM
Former Owner of
2016 Cedar Creek 36 POS (My Last FR Product)
09-04-2018, 09:42 AM
Let me clarify this:
4 inch bumper (most TT's and 5'vers)...they don't fit
4 1/2 inch bumpers...yes, they will fit
Now, I can force them in my 4 inch bumper and takes about 5 minutes each hose, but is much easier to just store in a large Rubbermaid tote.
