Old 08-27-2013, 05:09 PM   #11
Brother Les's Avatar
Originally Posted by littleb View Post
yup got a pressure reg. actually carry a spare. that's not it... I know it will stay in the lines lol. but when hooked up its steady drip when not hooked up to anything its still a real slow drip ..where is water coming from? it still drips now and its been 10 days or so since I parked it .. I am baffled.
These two lines coming out of the bottom of your unit are your 'low point' drain valves for when you want to drain all of your water lines. The blue is your 'cold' line and the red is your 'hot' line. Your water heater is in your 'hot' line and it has 5/6 gals of water in it..... it is still draining.
Blessings
Brother Les
Old 08-27-2013, 05:09 PM   #12
fonzie's Avatar
Well you still have water in the lines and the water heater, so if it's a slow drip it will take a while to empty. Tighten up the cap if that's what leaking......a picture always helps..
Fonzie
Old 08-27-2013, 05:51 PM   #13
Blessings
I am a bonehead lol forgot about that....feel better now though ty... as for why there is a clamp and valve on the hot and nothing on the cold I am still unsure but the cold does not drip at all...
littleb is offline   Reply With Quote
Old 08-27-2013, 05:57 PM   #14
Are you 100% sure that the two tubes that you are looking at are your low water drain valves? If one has a clamp and valve on it and the other has 'nothing' but a tube...... this sounds like your Fresh Water tank tubes....One is a 'drain valve' tube to drain your Fresh water and the other is an 'over flow/breather' tube.
You should have 4/Four/for/fer tubes under your camper that you can plainly or not so plainly see....
two on the fresh water tank and two to drain your hot/cold water lines......
Can you find all four tubes?
Brother Les
Old 08-27-2013, 06:26 PM   #15
cbauch
My blue and red are dripping and i have a wet carpet in bedroom, its a very small area and my rv is brand new. 2 weeks and i have had nothing but problems. It looks like the fresh water tank is under the wet area. I am hooked up to city water line. I don't know where its coming from
cbauch is offline   Reply With Quote
Old 08-27-2013, 06:49 PM   #16
Your dripping tubes are the least of your worries. they do have maybe too much water pressure on the water lines.
Do you have a Pressure Reducer on your city water?
Unhook from city water.
Can you see the Fresh Water tank from the under side of your unit?
If there is a cover under the camper, you will have to take out some screws and find out where you leak is.
It sounds as if the 'city water' is leaking past the water pump and filling the fresh water tank and 'maybe' a hose came loose and spraying water 'upward'.
1) the pressure should never be so high from the city water supply to back fill your fresh water tank. RED FLAG..... this is maybe one problem.
2) water is spraying from somewhere to the underside of your floor. RED FLAG.
this is another problem.
YOU CALL the sDealer that sold you this thing and tell him to FIX IT......
YOU tell the sDealer to have someone once again walk you through everything on your camper....
YOU tell the sDealer that the tubes are not to leak at all. That there is a water leak somewhere else and you want it found and fixed asap.
YOU tell the sDealer (if the fresh water tank filled up from city water),that the back flow valves on the water pump do not work and that you want the whole water pump replaced.
a
If this is a 2014..... It is newer than new and I would bug the heck out of that sDealer with everything that I thought was wrong or did not understand. He took your money and he needs to stand behind his product.
Brother Les
Old 08-27-2013, 06:54 PM   #17
cbauch
Thank you, this makes sense....i do not have a pressure regulator but i will get one....my husband is in afganistan so i will have to figure this out. I called the dealership and they are suppose to be out here thurs. Morning for a list of things to fix......thank you so much for your help.
Old 08-27-2013, 07:02 PM   #18
cbauch
Carpet wet
I went out and turned off the city water, i cannot tell if their is water in fresh water tank, too dark now......should i try and drain the fresh water? I will pick up regulator tomorrow. Any other infor. Would greatly be appreciated. Thank you so much again
Old 08-27-2013, 07:19 PM   #19
1)I want to thank-your husband for his service and I pray that he and all of our troops leave that place quickly and safely (withdrawal date is 2014)
2) A high city water pressure may, I repeat may have caused all of your issues. Do not take responsibility for any of it. This should have been covered in your walk through and you should have been given a Pressure Reducer with the unit. The sDealer will cover this as it is his error and his shoddy product.
3) to find out how much water is in the fresh water tank. There are buttons beside the stove that tell you
a) battery power..... When plugged in it will show 'MAX' 4 lights. If only on battery power the lights should show 4 and go down as you use power from batteries only
b) Fresh Water tank. push button and it will show how much water is in tank
c) Grey waste tank
d) Black waste tank
e)water pump switch
f) electric water heater element if you have that feature.
I do not follow all of the threads so if you have a specific question you can private message me if you want. If I don't know the answer, I am sure someone on this board does.
Brother Les
Old 08-27-2013, 07:37 PM   #20
cbauch
It shows empty.....but i am going to leave the water off until thurs. I can use the public showers, etc. Thank you for the compliment for my husband i will tell him in a few min. When he gets on video chat. He will appreciate that. Cannot wait till thurs gets here to see what they have to say. Thank you again so much
