Old 12-28-2015, 07:28 AM   #1
wanderer69's Avatar
Low Cold Water Pressure, Hot Is Working
Just arrived in Arizona after spending a couple months in Texas. When I arrived and hooked to the city water there was very low cold water pressure in al the faucets and toilet. I switched to the water pump and same low cold pressure (fresh water tank is full). The hot water works fine. I let the water run for a few minutes on both city and water pump but still low cold water pressure. I removed the water filter thinking that may have gotten clogged. No change, still low cold pressure. I relieved pressure on the hot water tank and also checked that all valve's in the docking station were parallel to the water lines. I have run out of ideas if anyone has any I'm all ears!
Tom
2015 Chevrolet Silverado LTZ 3500 CC DRW Diesel
2014 Cedar Creek 36CKTS
wanderer69 is offline   Reply With Quote
Old 12-28-2015, 08:45 AM   #2
A32Deuce's Avatar
Sounds like something is pinching the water line just after feed for hot water heater. Not sure how it comes into or runs through your rig, but that is the direction I would go since you said it was fine before you moved. Hope this helps!
2012 SunSeeker 3100SS Toad-1962 Futura
A32Deuce is online now   Reply With Quote
Old 12-29-2015, 10:38 PM   #3
wanderer69's Avatar
Found it
Thanks all. Found the problem. The valves for the outside hose were turned off but I had a spray nozzle on the end of the hose and there was still water pressure in the hose. Released that water and then cold water worked fine again in all the faucets and toilet. Go figure
Tom
pressure, water
