11-08-2011, 09:01 AM
Low Hot Water Temperature
First night in my new fifth wheel and the water is getting warm but not hot. I am at work right now with no manuals, just wondering if anyone new if there was a temperatrure adjustment on the Hot Water. My Jayco that I traded had no adjustment and would scald you if you weren't careful. My water is warm enough to shower in, but without adding any cold water at all.
11-08-2011, 09:06 AM
It might be something as simple as your bypass valve being cracked open. Double check that 1st.
11-08-2011, 09:48 AM
I'm with mtnguy.
11-08-2011, 10:28 AM
Thanks guys, I will look at that first thing when I get home from work this afternoon.
11-08-2011, 11:56 AM
another cause is open valves on the outside shower.
11-08-2011, 12:37 PM
Asking because I don't know .......
Will it feed water around the valve body?
11-08-2011, 12:54 PM
I second (or third) the bypass valve. We camped all summer in our 2011 Surveyor that we bought in March. The water was luke warm but never hot. Wasn't a big deal as we were camping in hot weather but it was something I had on my list to look at more closely before the warranty is up. As I winterized last weekend and I took the panel off to get at the hot water heater valves, all three were wide open, apparently from the factory. I couldnt decide whether I was happy I likely found the issue for the hot water or a little foolish for not checking earlier.
11-08-2011, 05:15 PM
The Old Man
Yep, I've had the same thing happen and it was the bypass crossover valve still open.
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
11-08-2011, 06:49 PM
Okay, it is not the bypass valve. However I have made some progress. It is getting hot now with electric. However, the gas burner is not working. Is there a gas cut off valve other than the tank valves?
Cardinal 3450RL
Jerry, Johnnie, CC, Dixie Rose, and Beau
2012 Cardinal 3450RL - TrailAir Rota-Flex Pin Box, Equa-Flex Equalizers, Level Up Auto Level, Winegard SK-3005 Satellite System
2011 Chevy 2500HD - 6.6L Duramax, Allison Tran, Husky HD Aftermarket 5/1 Springs, Air Lift LoadLifter 5000 Air Bags, Drawtite Pro Series 20K Fifth Wheel with Square Tube Slider
11-08-2011, 06:56 PM
Cardinal 3450RL
This is gonna sound stupid, but, you did turn on the water heater switch on your monitor panel - right ?? The switch should be lit (probably blue) when in the "on" position, the DSI led should come on "red" and then go out when the burner lights correctly. If it stays red, there is a problem with the DSI system.
...VTX-AL
11-09-2011, 07:42 AM
Thanks for all the advice on this. I don't know what I did wrong or right, but I now have the hot water at the temperature I was expecting.
11-09-2011, 01:53 PM
From what I've read, the showerhead can be off, but if the h/c valves are open any amount, it can cause mixing of the two lines.
01-14-2012, 08:04 PM
itch'n to road trip
Remember: an RV is NOT like your home! The water heater in an RV is not nearly as efficient as your home water heater. Also think about the water temperature coming into the water heater. The colder the water the longer it will take to warm. Also the RV water heater is not insulated as well as your water heater at home.
2012 Ford F-250 King Ranch Super Crew Cab 4x4
2014 Work & Play 25ULA
Paula Drake, Ken Cooksey, Sunny Delight, Valor & Scarlet Begonia
Jasper Ga.
