Old 12-30-2014, 11:34 PM   #1
Low kitchen tap pressure
I only have less than a pencil width of water coming out of both hot and cold water kitchen taps. All others flow full stream.
Any ideas on what to look for? And where?
Headstart is offline   Reply With Quote
Old 12-31-2014, 01:31 AM   #2
TURBS's Avatar
Take your screen out of the tap.
It probably needs cleaned.
Old 12-31-2014, 09:54 AM   #3
agree
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 12-31-2014, 10:56 AM   #4
iceblaze580's Avatar
Try soaking it in CLR
iceblaze580 is offline   Reply With Quote
Old 12-31-2014, 11:01 AM   #5
Ford Idaho's Avatar
Yep, if there are more than two try just two.
Old 12-31-2014, 11:39 AM   #6
Denver, CO
garbonz's Avatar
Is this a new problem or existing from new? Sometimes construction debris can get into the lines and pile up at the elbows or where the pipes go into the faucet. Check the screens first, but if it doesn't help then disassemble the faucet itself and see if there is any constriction in there. the fact that it is only happening to one faucet AND both hot and cold suggest it is in the faucet or the screen at the tap.
2017 Fuse 23T
Old 12-31-2014, 11:42 AM   #7
Campin Cajun's Avatar
If your sink is in a slide the lines may be pinched also.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 01-01-2015, 02:27 PM   #8
Bubbamace's Avatar
My Georgetown XL gave me grief from new to about a year and one half out with plugged screens in both the kitchen and bathroom faucets and the toilet. Every time we went out camping everything would plug up. I got into a routine of cleaning the screens every time we set up. Finally, whatever was in the tanks got flushed out. The material was black plastic looking debris. Good luck with the problem and Happy New Year.
Bubbamace is offline   Reply With Quote
Old 01-01-2015, 03:27 PM   #9
Check the screen at the hook up in your utilities center as well. Mine was pretty dirty there and at the kitchen sink. After it was cleaned the pressure returned to normal. It's easy to overlook the easy things when you start thinking from worst case scenario.
Nastyfoot is offline   Reply With Quote
Old 01-02-2015, 09:46 AM   #10
Team Bleu
Had the same problem, but mine was white particles and calcium. Still getting it no matter how many times we flushed the tanks
DBsRedVett is offline   Reply With Quote
pressure
