Close - those caps match the fresh water tank drain.
My caps are gray plastic and hex in shape so you can put a wrench or socket on them (which I did...no, nothing is cracked!)
No gaskets, before or after my meddling with things. The threads I would think are pipe threads - tapered - so wrapped some teflon tape and its a lot better, but still dripping.
I don't think a hose type gasket would fit in the cap. Pipe dope would do it, but i've always had to use heat to get that apart and everything's plastic.
Originally Posted by f1100turbo
