Old 04-08-2013, 03:57 PM   #1
prof_fate's Avatar
low point drain leaks - options?
I drained my system last fall and got things back together yesterday and today.
The low point drain 'caps' are leaking...not much once I added teflon tape and gorilla torque...but still a drop here and there when under 55psi city pressure.
Anyone got a solution? Would gluing valves on there be a good option? No more caps!
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 04-08-2013, 04:05 PM   #2
Always Learning
Heck, my ball valves are leaking a drop or two... Have been since I lost the caps when I did something at the end of last season. So far, I've lived with it...
Really need to take them off, rewrap tape on them and put them back on.
Old 04-08-2013, 04:07 PM   #3
TURBS's Avatar
Did you loose the gaskets?
Old 04-08-2013, 04:09 PM   #4
TURBS's Avatar
Is this what u have ?
Old 04-08-2013, 04:28 PM   #5
prof_fate's Avatar
Close - those caps match the fresh water tank drain.
My caps are gray plastic and hex in shape so you can put a wrench or socket on them (which I did...no, nothing is cracked!)
No gaskets, before or after my meddling with things. The threads I would think are pipe threads - tapered - so wrapped some teflon tape and its a lot better, but still dripping.
I don't think a hose type gasket would fit in the cap. Pipe dope would do it, but i've always had to use heat to get that apart and everything's plastic.
Attachment 27434
2011 Grey Wolf 28BH
Old 04-08-2013, 04:32 PM   #6
Go to lowes or hd and buy 2 1/2inch pvc ball valves. Use a lot of teflon tape and srew them on. This fixed my leak problem.
Poppy Bill is offline   Reply With Quote
Old 04-08-2013, 04:34 PM   #7
prof_fate's Avatar
Originally Posted by Wiscampsin View Post
Isn't 55psi a little high for a camper?
I don't have a guage on the system but 3 years ago they put in a new water tank in town and came and measured pressure. 40 to 60 is normal, we measured 55.
A friend in the city had over 75 on his house and installed a regulator to keep from blowing up garden hoses.
What is normal house water pressure
2011 Grey Wolf 28BH
Old 04-08-2013, 04:35 PM   #8
prof_fate's Avatar
That's what I was thinking. I've had great luck with ball valves on my house plumbing.
Good to know it should work!
2011 Grey Wolf 28BH
