Old 04-22-2018, 06:58 PM   #1
Adony's Avatar
Low Point Drain Lines
Are the low point drains pressurized if using the on board water tank / pump? I store my TT in an area that has no water supply. I thought if I filled the on board water tank at a faucet nearby the storage area..I might be able to attach a hose to one of the low point drains, turn on the pump and wash the trailer where it is stored. The hose would have an on/off nozzle on it to control the water and let the pump rest when not needed. . Does this sound like something that might work?
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 04-22-2018, 07:04 PM   #2
Flybob's Avatar
Yes that will work, but washing the RV would be a strain on the Water Pump. Also the flow rate will be lower than home, but it will work
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
drain
