Old 11-03-2017, 10:46 AM   #1
Low point drain plugs stuck
Do these caps screw off? I have been really leaning on them but am afraid to break something. They didn't leave me much hose to work with.
minilite2507s is offline   Reply With Quote
Old 11-03-2017, 10:57 AM   #2
Yes.
Hold the upper part (between the cap & PEX clamp) and turn off.
Lefty loosie - righty tightie.
They have a rubber washer and I suspect someone overtightened.
They really don't have to be that tight.
Once removed, think about 1/4 turn ball valves either on the end or above the floor and you'll thank yourself next time.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 11-03-2017, 10:58 AM   #3
crunchman12001's Avatar
Yes, the caps unscrew. Use a wrench to hold the top part and some channel locks to grab the lower part to unscrew.
2015 F-250 FX4
drain
