11-09-2018, 12:47 PM
Low point drain valves
Had to winterize so I changed my low point drain pex caps while I was at it. Replaced with Zurn Pex Valves from Zoro Tools.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
11-09-2018, 01:02 PM
Nice find!!
11-14-2018, 10:13 PM
Are they 1/2"?
2018 Forester 3011 DS
11-14-2018, 10:30 PM
Yes. 1/2"
11-15-2018, 03:07 PM
Yes. 1/2"
Thanks. I just did an overnighter with no hookups. Tried to shower and the previously full fresh tank was empty. When I looked I saw this.
No cap on cold water low point drain. Also, no valve on fresh tank drain, unless I missed it.
Since I have to get something, I might as well do the valves. Thanks.
11-15-2018, 03:22 PM
Anyone know if those valves are available at Lowes/Home Depot?
11-15-2018, 03:30 PM
My wife is checking today.
11-15-2018, 03:52 PM
Yes. Look in the pex section. But I noticed the crimped in fitting is gone.
You will either need a crimp style valve, crimp rings, crimper tool or a compression fitting like this Flair-It 16892 Plastic Straight Stop Valve, 0.5" Size https://www.amazon.com/dpB000BQT694/..._h0D7BbGE9C5BA
I have found the crimp stuff at Home Depot and the flair-it compression stuff at ace hw.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
11-16-2018, 01:14 PM
Now I feel better, because I've done this on our previous trailer, and on our current. On the previous trailer, I cut out the cap fittings, and put in pex crimped valves. On the current trailer, I just replaced the screw on caps with screw on valves. Worked great for winterizing this year.
11-16-2018, 01:35 PM
Travis, where did you find the screw on valves?
11-16-2018, 01:57 PM
Well, she bought caps at an RV dealer.
11-16-2018, 07:20 PM
11-16-2018, 11:34 PM
Since I have to get something, I might as well do the valves. Thanks. Attachment 191513
The blue line should not have any cap on it. It is the fresh water holding tank drain. It is opened and closed by a quarter turn valve usually in the water bay. The red line is the one and only low point drain. It should only be used when the water heater is in bypass mode.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
11-19-2018, 06:41 AM
Thank you 'bob213'. I ordered 2 from Grainger on Saturday.
Jim & Kathy
Bailey, waiting at the Rainbow Bridge
Gracie, a rescued Beagle
2007 Chevy Tahoe
2008 FR Surveyor 233T
