Old 11-09-2018, 12:47 PM   #1
bob213's Avatar
Low point drain valves
Had to winterize so I changed my low point drain pex caps while I was at it. Replaced with Zurn Pex Valves from Zoro Tools.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 11-09-2018, 01:02 PM   #2
Nice find!!
WFD473 is offline   Reply With Quote
Old 11-14-2018, 10:13 PM   #3
dcheatwood's Avatar
Are they 1/2"?
2018 Forester 3011 DS
dcheatwood is online now   Reply With Quote
Old 11-14-2018, 10:30 PM   #4
bob213's Avatar
Yes. 1/2"
Old 11-15-2018, 03:07 PM   #5
dcheatwood's Avatar
Yes. 1/2"
Thanks. I just did an overnighter with no hookups. Tried to shower and the previously full fresh tank was empty. When I looked I saw this.
No cap on cold water low point drain. Also, no valve on fresh tank drain, unless I missed it.
Since I have to get something, I might as well do the valves. Thanks.Click image for larger version
Old 11-15-2018, 03:22 PM   #6
Anyone know if those valves are available at Lowes/Home Depot?
ousooner is offline   Reply With Quote
Old 11-15-2018, 03:30 PM   #7
dcheatwood's Avatar
My wife is checking today.
Old 11-15-2018, 03:52 PM   #8
Yes. Look in the pex section. But I noticed the crimped in fitting is gone.
You will either need a crimp style valve, crimp rings, crimper tool or a compression fitting like this Flair-It 16892 Plastic Straight Stop Valve, 0.5" Size https://www.amazon.com/dpB000BQT694/..._h0D7BbGE9C5BA
I have found the crimp stuff at Home Depot and the flair-it compression stuff at ace hw.
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is online now   Reply With Quote
Old 11-16-2018, 01:14 PM   #9
Now I feel better, because I've done this on our previous trailer, and on our current. On the previous trailer, I cut out the cap fittings, and put in pex crimped valves. On the current trailer, I just replaced the screw on caps with screw on valves. Worked great for winterizing this year.
ImTravis is online now   Reply With Quote
Old 11-16-2018, 01:35 PM   #10
Travis, where did you find the screw on valves?
drain, valve
