Old 11-02-2011, 07:34 PM   #1
JEFF BARTON's Avatar
Low point drains
Can i use my low point drains to winterize my tt with the air compressor instead of city water hook up? These are threaded fittings so i can use the same fitting that i use for my in ground sprinkler system.
JEFF BARTON is offline   Reply With Quote
Old 11-02-2011, 07:45 PM   #2
sherdep's Avatar
I dont think you can blow the water back thru the city water connection so the water that you blow back has to go somewhere - either in the tanks or the sinks.
Are you looking to just blow the water out of the lines or looking to add antifreeze also?
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 11-02-2011, 07:55 PM   #3
I just want to blow water out of lines
Old 11-02-2011, 07:59 PM   #4
sherdep's Avatar
if you open the valves on the faucets and shower and have enough air pressure I dont see why you couldnt
dont forget you will probably need to do something about the hot water heater - like drain it and put it in Bypass so the water doesnt all go into the hot water tank prior to pushing air into the lines.
Old 11-02-2011, 08:04 PM   #5
That's what I thought I will make sure I drain holding tanks and put anti freeze in traps
Old 11-03-2011, 10:10 AM   #6
Important to keep the air pressure to about 40 PSI max. Open low point valves first and let as much water drain out as possible. After air pressure is applied, open valves and/or faucets one at a time, starting with the ones farthest from your city water inlet, and shut off each before moving to the next. Don't forget the outside shower, inside shower and toilet supply line. Lastly, open low point drains again to drain off any water that was forced there. I always leave faucets cracked open during the storage period.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 11-03-2011, 12:46 PM   #7
Herk7769's Avatar
Jeff,
Like Sherdep said, you MUST still blow out the city water check valve from the outside to get the trapped water out of the check valve. If you do not, you will most likely be buying a replacement city water port in the spring.
Also, if you have a Turbo-Flush, you must also blow it out to clear trapped water in ITS check valve.
Don't forget your water pump will not flush out from the low point drains because it also has a check valve filled with water that will prevent it from doing so.
Additionally, if you have a "whole camper" water filter, you will need to drop the filter container and remove the filter; drain, then replace it before you blow out the lines.
HAM CALLSIGN - KC3FFW
Old 11-03-2011, 02:15 PM   #8
dretired's Avatar
Originally Posted by herk7769 View Post
Jeff,
Herk.. If the trailer was winterized with the anti freeze method by sucking anti freeze through all the water lines and the waterheater was bypassed and drained would the city water fill and black tank flush still need to be blown out ??
dretired is offline   Reply With Quote
Old 11-03-2011, 02:56 PM   #9
Yes they will also. Youroo!!
Old 11-03-2011, 04:59 PM   #10
Herk7769's Avatar
Ps you can also manually pop the city water check by removing the screened washer and pressing the white plastic check valve stem. Hold until the pink antifreeze comes out.
