Old 11-01-2013, 06:44 PM   #1
Scottsmenn's Avatar
low point drains
Hey all, just wondering, a close friend told me I should leave my low point drains open all winter. I have never heard of that before. I just assumed that after you drained them they would fill up with antifreeze when the antifreeze is added through the water pump. Any thoughts?
2013 Forest River Grey Wolf
2004 Ford Expedition
Camping Days 2013: 6
Scottsmenn is offline   Reply With Quote
Old 11-01-2013, 06:50 PM   #2
Ford Idaho's Avatar
I would not leave them open.
Have you checked to see if there is AF in the drain yet?
Old 11-01-2013, 06:59 PM   #3
Scottsmenn's Avatar
No, I plan to winterize it tomorrow.
Old 11-01-2013, 07:03 PM   #4
Ford Idaho's Avatar
Ah, very good.
Put in a gallon or so and then check the low points.
Old 11-01-2013, 07:04 PM   #5
aka Windjammer2012
Crankshaft's Avatar
IF you just blow out to winterize you CAN leave your low point drains open but not neccssary. IF you use anti-freeze, then you MUST close the drains otherwise the anti-freeze will be expelled.
Wayne & Vonnie
Layla (American Eskimo dog)
2012 Windjammer 3008W
2004 GMC 2500 HD CC Longbed
Crankshaft is offline   Reply With Quote
Old 11-01-2013, 07:06 PM   #6
We pretty much don't have "winters" here in So Cal so I leave my low point drains open. One thing I did find out on my last outing (only two outings so far) is that the blue drain is the hot and the red is the cold.
tosh99 is offline   Reply With Quote
Old 11-01-2013, 07:07 PM   #7
AquaMan's Avatar
After I blow my lines and add antifreeze through the pump, I release the pressure and drain the lines of whatever antifreeze might come out. Might sound like a waste, but I know whatever is in the lines is antifreeze, and the lines don't need to be full to be protected. I then cap the lines to keep bugs and such out. If you don't want to drain the lines, I would at least release the pressure.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
