Old 10-03-2012, 05:09 PM   #1
MikeInColo's Avatar
Low point drains/fresh water drain left open?
I was planning on winterizing my rig this weekend and was going over my notes to refresh my memory. In my notes I have, "Open low point drains." I also have "Close low point drains."
Does anyone leave these drains open all winter? Is there any risk to leaving them (including the fresh water drain) open or closed? I have the blue/red low point drains.
Thanks.
MikeInColo is offline   Reply With Quote
Old 10-03-2012, 05:21 PM   #2
TURBS's Avatar
Thanks.
Only reason you may want to close them would be little critters climbing aboard !
Turbs
Old 10-03-2012, 07:06 PM   #3
Oakman's Avatar
I’m guessing you only blow out the water lines and don’t pump antifreeze into them. The main reason for closing the low point drains would be to keep the antifreeze from draining out.
Leaving the fresh water drain open won’t hurt anything other that giving an insect a place to winter.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 10-16-2012, 11:58 AM   #4
does anyone know where the low point drains are in a 2000 Wildwood 37Bhss
Reneedann is offline   Reply With Quote
Old 10-16-2012, 12:15 PM   #5
Campin' in Canada
ParkManCan's Avatar
Not sure about a 2000 but our 2011 Bhss has them just to the right of the GW/BW drain outlet, tucked up short just sticking out of a ball of spray foam. Red and blue lines with caps on them. Had trouble finding them myself!
2011 Wildwood 37bhss2q
Permanently Parked
Just me & the DW
ParkManCan is offline   Reply With Quote
