Old 07-22-2018, 06:32 PM   #1
Send a message via AIM to jk31668
low point water drain help
was hooked up in a nice c/g when i noticed a slow drip from the cold water low point drain. was hooked up to city water. fresh water tank is empty. any thoughts? what does the other end of that blue hose connect to? thanx
2010 sunseeker 3100ss
jk31668 is offline   Reply With Quote
Old 07-22-2018, 06:36 PM   #2
Flybob's Avatar
That blue hose is the lowest point in the cold water plumbing in your RV. It is possible that the plug is not in tightly and the pressure is high.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-22-2018, 06:38 PM   #3
Mr. Dan's Avatar
Low point drains hook to the water lines inside the unit. The blue one is for draining all (as much as possible) of the COLD water out of your interior lines. The red one is for draining the HOT water. Most owners use these to drain water out of their units to start their winterization process. A few on here drain their water after every trip.
Old 07-22-2018, 09:35 PM   #4
I had to use plumbers thread sealing tape on mine to prevent dripping.
msdundas is offline   Reply With Quote
Old 07-23-2018, 12:51 PM   #5
BooBoo23's Avatar
The low point drain is not connected to your fresh water tank. The fresh water tank has a separate drain valve. As already mentioned the low point drain is for the water system, one drain for hot and one for cold.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 07-23-2018, 01:00 PM   #6
Low point drains
I replaced the plugs with check valves purchased at Menards. I got the idea from the FROG. I brought one of the plugs with me to match up the thread sizes. After disconnecting from the city water, I've always drained the system between trips. Opening the drain valves and all the faucets along with the water heater overflow/check valve. Drains the system quickly and efficiently.
At 8+ lbs per gallon, why bother hauling the extra weight?
Of course, I do make sure all the valves are closed before leaving.
Denny B is offline   Reply With Quote
Old 07-23-2018, 05:31 PM   #7
LandKKnight's Avatar
I always thought the low point drain drained the tank, glad I read this. Apparently our tank drain valve is under the bed with the tank. Might be a dumb question but where does the water come out when u drain via that valve?.
Kevin and Linda Knight
2018 Isata 5 30FW 4x4
dog-mobile for Sophie, Roxy, and Kai
Windsurf-mobile for us
LandKKnight is offline   Reply With Quote
Old 07-23-2018, 08:26 PM   #8
BooBoo23's Avatar
You will need a Isata owner to answer that. MH's have compartments for everything, I will assume it comes out under the RV somewhere, just don't know where.
KT4W
Old 07-23-2018, 08:34 PM   #9
BooBoo23's Avatar
One more note, you can't drain the fresh water tank using the pump as the pickup is on the side of the tank, not the bottom so there will always be water remaining in the tank, remember that when you winterize. Only 3 holes in the fresh water tank, the inlet, the outlet for the pump and the drain in the bottom.
KT4W
Old 07-23-2018, 08:58 PM   #10
Herk7769's Avatar
So, draining your hot water heater through the low point drains is a bad idea.
Sooner or later the water crud that is being sucked into your cold water lines will get pushed into your toilet tank flush valve or your sink faucet valves.
I suggest instead, for you to close off the hot water tank by closing the winter isolation valves and drain just the water lines using the low point drains. The water heater tank should only be drained and flushed from the outside using the Anode/Drain hole.
ID:	181012   Click image for larger version
ID:	181014   Click image for larger version
ID:	181015   Click image for larger version
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 07-23-2018, 09:07 PM   #11
Dang...where do you get your water from?
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
mogman is offline   Reply With Quote
Old 07-23-2018, 09:27 PM   #12
BooBoo23's Avatar
City water treatment is mainly to remove bacteria not the minerals, large stuff is naturally removed but not what is dissolved and in suspension. Heated water brings those minerals out of suspension. Have you ever seen a shower head "lime up". Growing up on the farm we always had well water which is not treated although it is usually filtered naturally through the sand layer in the earth and when we would visit relatives on other farms the water tasted different, some had so much iron in the water you couldn't wash you hair in it, a lot of time it had a sulfur smell or as some said like "rotten eggs" ( I don't know what rotten eggs smell like) Just had to make sure the well was a good distance from any cattle or hog lot. Most of the time the sediment in the Suburban water tank is from the sacrificial anode rod and some of it is natural rust flaking off of the inside of the tank the same as the hot water tank in your home which also has a sacrificial anode rod, newer tanks are glass lined now so not quite as bad.
KT4W
Old 07-23-2018, 09:35 PM   #13
Herk7769's Avatar
Bits of anode and calcium will collect at the bottom of your tank even from the best of sources. Well water or high mineral water at some campgrounds will make the crud worse.
I always flush from the anode drain plug with the tank isolated and never fail to get crud flushed out.
Here is what happens when a bit of calcium gets pushed into your flush valve.
Name:	Flush Valve 1.jpg
ID:	181023   Click image for larger version
Name:	Flush Valve 2.jpg
drain, water
