Old 05-04-2014, 03:32 PM   #1
Low pressure at kitchen sink
Hi all.
I just dewinterized my 2007 Roo, and noticed that, although I have good pressure in hot and cold at the other faucets (shower, bathroom, and outside shower), the hot and cold taps in the kitchen both have noticeably lower pressure. Tracing the plumbing, it looks like the kitchen is at the end of the line, but I can't find any valves, or kinked lines.
I don't recall seeing this as a problem in the past 3 years I've owned the Roo.
Thanks in advance for any replies!
-John-
jgtrupe is offline   Reply With Quote
Old 05-04-2014, 03:43 PM   #2
It's always a good idea to search FRF by keywords to an issue. Search low water pressure at faucet. You will find your possible solution.
Old 05-04-2014, 03:46 PM   #3
Iggy's Avatar
Originally Posted by jgtrupe View Post
Hi all.
-John-
If it is low pressure on both hot and cold.... Have you taken the faucet strainer out and clean it?
2012 Georgetown XL - 378TS 66K + miles
Old 05-04-2014, 04:22 PM   #4
H2oski
X2 on the strainer. Had the same problem with mine this spring. Unscrewed faucet tip and cleaned it. Good pressure now. Good luck
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 05-04-2014, 07:48 PM   #5
Hi all.
-John-
De winter wise the commodes and times before running water through sinks. This will limit strainers from getting stopped up.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
pressure
