Low Pressure on Pump
So I am curious if any of you have experienced this...
When I run the water pump I have a surge of normal water pressure, then it slows to a very low flow.
If I am at the pump I can see that on the intake side, at the small screen filter, it appears that it can't pull the water fast enough from the tank. Meaning it fills the bowl to pressure, but as soon as a valve (sink or other) is opened it just can't pull it up as fast as it pumps out. I blew the tank line out before the winter, plus fully drained. Of course drained first then blew out.
Has anyone encountered this? Almost seems to be getting a little air in the line?
2018 Cherokee 274DBH
2015 Chevy 2500 4x4 Crew Cab
Recurve R6 WDH w/Sway Control
Days Traveled:2021-51 / 2020-43 / 2019-37 / 2018-30
