Old 10-05-2016, 11:44 PM   #1
Low water pressure
We have taken our new to us camper out twice now. Both times we noticed very little water pressure when hooked up to city water with a pressure regulator. I have tried two different regulators with the same result for both. If we use the water pump with our tank it is much better. Any suggestions would be great.
2010 Toyota Tundra SR5 4x4
2013 primetime tracer executive 3200BHT
Crshamp is offline   Reply With Quote
Old 10-06-2016, 01:54 AM   #2
NMWildcat's Avatar
Have you tried it without any regulator? What size hose are you using? Do you use any filters? Have you checked the pressure at the park faucet? Have you checked the screen on your city water input?
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 10-06-2016, 03:31 AM   #3
I have always heard it was bad to run it without a regulator, so I have not. I am using a standard drinking water hose. The screen looks clear as well. The pressure always seems to be strong when I flush the water faucet before I hook up. I have not located a filter in the trailer yet. Don't even know where to start looking.
Old 10-06-2016, 06:06 AM   #4
TURBS's Avatar
I've never used a regulator.
Been camping ⛺️ for 20 + years
Old 10-06-2016, 06:45 AM   #5
Fred H.'s Avatar
Regulators are known to go bad. If you encounter problems like your having I would purchase another one.
I purchased this one: Adjustable Water Regulator - Lead Free - Valterra A01-1117VP - Faucets & Inlets - Camping World
It works great and you can see what the pressure is. It is also adjustable using a flat head screwdriver to set the pressure your comfortable with.
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 10-10-2016, 04:10 PM   #6
Just got back from a long trip. we had the same problem. We found a hi flow pressure regulator at a camp store and it worked great.
jed7 is offline   Reply With Quote
Old 12-04-2016, 12:27 PM   #7
Currently on the road, but when I get back the first thing I'm going to buy is an adjustable regulator. What pressure are you using? I can't see anywhere what the recommended or maximum pressure should be.
2010 Wildcat 28RKBS (purchased March 2016)
Pullrite #2700 Superslider
2006 Dodge Ram 2500 2X2 diesel
2016 - 41 days (2,800 miles)
kejorgensen is offline   Reply With Quote
Old 12-04-2016, 12:29 PM   #8
NMWildcat's Avatar
We use a 50psi high flow regulator.
pressure, water
