Old 05-23-2017, 01:50 PM   #1
Low water pressure in kitchen
We have adequate water pressure in the bathroom but almost zero in the kitchen. No leaks, verified the winterizingbypass valves are in the correct position, but still just a trickle. We do have hot and cold cold everywhere, we do not have an outdoor shower. Our trailer is a 27rkss 2017. TIA
robertanderson is offline   Reply With Quote
Old 05-23-2017, 01:54 PM   #2
fonzie's Avatar
Take the aerator off and clean it, most likely debris inside.....
Fonzie
Old 05-23-2017, 01:57 PM   #3
dcheatwood's Avatar
Yep. Little pieces of water heater corrosion, and other sand like bits will stop it up. Unscrew the aerator, clean it out and you should see big improvement. Then you can do the bathroom faucets just to make sure. 🤣
2018 Forester 3011 DS
Old 05-23-2017, 02:13 PM   #4
All fixed now. it was a clogged aerator. Thanks
Old 05-24-2017, 05:26 PM   #5
Amazing! Every time I have a problem, I check the forum and someone else has asked the same question and you all supply the answer. I checked my aerator and that was exactly what my problem was as well. Thanks.
820DirtBoy is offline   Reply With Quote
pressure, water
