05-06-2015, 10:32 AM
Low water pressure in kitchen sink
I'm having a water pressure issue with my kitchen sink in my Chaperrel 29bhs. My shower, bathroom sink, and outdoor kitchen sink all work fine. My kitchen sink pressure was normal last night but as of this morning it only trickles. Any ideas?
05-06-2015, 10:59 AM
Yes you probably have something in the faucet head blocking it. Unscrew the faucet cap and look in it for stuff and run the water with it off to flush it.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
05-06-2015, 11:01 AM
Plugged screen in the facet head.
Just cleaned mine this past weekend, I also removed the "water saving" device.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
05-06-2015, 06:48 PM
That's exactly the problem. Clogged screen. Should have checked that first but my paranoia kicked in and I thought it was something catastrophic. Thanks for the responses
05-07-2015, 08:12 PM
Just started having this same problem, cleaned the screen out, it did have some like small rocks or some hard particles, however that did not resolve the issue.... what else should I look for?
Thanks,
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
05-07-2015, 08:29 PM
I have the faucet with the retractable spray head. I noticed the same thing but my issue was the counter weight on the spray hose. The weight (used to keep sprayer in the faucet)was causing sprayer hose to kink. I loosened with weight, sliding it up a couple of inches. That stopped the problem.
05-07-2015, 08:49 PM
The retractable is what we have. Thanks for sharing, will check it out.
05-07-2015, 09:02 PM
Toy-aholic
Thanks,
how about the inlet screen where you attach you incoming water hose?
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
05-07-2015, 09:12 PM
Not sure what you mean? IF you mean the screw on/off connection where the flex hose attaches to the nozzle, yes we did check that and cleaned some crude from that also.
05-10-2015, 12:46 PM
Weight is not kinking the hose, the screens are cleaned out, even removed the faucet head and flushed it out. Problem is still there. bathroom water pressure is good/normal. So I am at a loss for solution.
05-10-2015, 12:55 PM
Pull the head off and throw the metal restrictor in the trash. You have to have trash in either the hose, faucet head, strainer or the faucet body itself.
05-10-2015, 02:06 PM
Toy-aholic
possibly the faucet valve itself obstructed
06-24-2016, 10:57 AM
Where is this water restrictor you speak of? I have the same problem as the OP. Is it in the faucet head or along the line somewhere?
06-24-2016, 11:20 AM
Water flow, kitchen
@bkearney that would be the screw on at end of the water spout, usually there is a screen that collects debris or an orifice in there but can restrict water flow. In my case the dealer replaced the whole faucet saying it was defective, water flow is now adequate.
