Old 05-22-2013, 07:47 AM   #1
Low Water Pressure Throughout Trailer
I have a 2013 Silverback 35QB4 and we are on our own 1/2 acre lot with a cistern and pump. I have 2 connections at the pump, one to my trailer and one for a garden hose thats free to use outside for watering trees / plants etc.
There is plenty of pressure coming from the pump itself as the garden hose has enough pressure to spray off decks, wash boat etc. Yet, the pressure within the trailer is very low everywhere, shower, toilet, sinks, etc. The pump is set to max out at 60 psi and I don't have a pressure reducer at my connection to the trailer.
Any ideas? Am I missing something simple?
Sean is offline   Reply With Quote
Old 05-22-2013, 07:48 AM   #2
TURBS's Avatar
Is your water filter plugged?
There should also be a sediment screen near your pump.
Very fine micron filter?
Old 05-22-2013, 08:13 AM   #3
Check the screen where you hook up the hose to your camper.
Old 05-22-2013, 09:26 AM   #4
I do have a water filter and it's fairly new so it should be fine. Saying that though, I will simply remove the filter and see if that makes a difference. Sadly I'm not back out there for a couple weeks so I can't even try it out for a while.
Thanks.
Old 05-22-2013, 10:11 AM   #5
...Any ideas? Am I missing something simple?
Remove all the aerators on the faucets and clean and throw the water savers away, (the little flat washers with a hole in them)
Old 05-22-2013, 10:44 AM   #6
daydreaming about camping
jeeplj8's Avatar
had a similar problem in our old pop-up. curiously the pressure was ok off the pump. found a couple dozen dead ladybugs in the inlet line...
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
Old 05-22-2013, 11:09 AM   #7
HA, I'm going to tell my wife and daughter that and see if they freak out.
Old 05-22-2013, 11:09 AM   #8
I'll take a look. I didn't know each faucet has a restrictor on it.
Old 05-22-2013, 11:11 AM   #9
jeeplj8's Avatar
mine still will not drink the water from the tap...
Old 05-22-2013, 11:19 AM   #10
Cant say I blame her.
Old 05-22-2013, 11:45 AM   #11
TURBS's Avatar
Mine do or they go thirsty.....
I got beer so I'm good...
Old 05-22-2013, 11:53 AM   #12
TURBS's Avatar
City slickers..........
Old 05-22-2013, 12:08 PM   #13
BombDoc's Avatar
See..........where I get it from??
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-(20) 2019-0
BombDoc is offline   Reply With Quote
Old 05-22-2013, 12:25 PM   #14
TURBS's Avatar
Aaaaaa yep
Old 05-22-2013, 12:32 PM   #15
And from both forks of his tongue too!
