Old 11-18-2015, 04:08 PM   #1
acadianbob's Avatar
Lubricating Black & Grey Valve Slides
Mine are getting "sticky". What have you found that is best for lubricating these guys?
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 11-19-2015, 06:19 AM   #2
waiter21's Avatar
Every couple months when I'm doing a dump, I give the valve stems a squirt of TriFlow.
Its a teflon based lubricant.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 11-19-2015, 06:50 AM   #3
KyDan's Avatar
There was a great tip in Trailer Life mag this month.
A picture would be worth a 1000 words but that would be copyright infringement.....
In a nut shell -- close the valve and drill a tiny hole in the back end of
the valve body near to where the valve stem comes out- like an inch away
from the stem. Then put the capillary tube of a can of spray lube in the hole and
spray away. He then sealed the hole with a tiny screw until the next time.
Supposed to last several months or dumps.
He was using white lithium spray grease but I think silicone spray would work
fine too.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 11-19-2015, 08:09 AM   #4
A32Deuce's Avatar
I had one sticking and gave the shaft a shot of WD40. Like new again!
A32Deuce is offline   Reply With Quote
Old 11-20-2015, 12:00 PM   #5
Explorer
Wow, Kydan why didn't I think of that. I am going out with the drill momentarily, after finding the article.
I yearly take a very long Q-tip dipped in O-ring lube and slather the inside of the gate valve but it only last about 10 dumps and then gets sticky again.
Thanks for posting; always find new ideas out here.
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
black, cat, slide, slide out
