Old 05-20-2018, 12:36 PM   #1
Canadian Member
Lubricating Manual Waste Valves
Has anybody here tried this:
https://www.youtube.com/watch?reload...ature=youtu.be
My black tank valve is a bit sticky.
2019 Rockwood Signature 8290BS
itat is online now   Reply With Quote
Old 05-20-2018, 02:25 PM   #2
if only the valves were that accessible! many of them are buried up under the underbelly where you can't see them, let alone access them. I have tried to put some silicon oil on the portion of the shaft that has the handle on it and exercise it hoping the oil will get inside and lubricate the shaft / cable. marginal to no improvement.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 05-20-2018, 06:11 PM   #3
TexasGolfBum's Avatar
I agree can't get to my Forest River Cedar creek due that it's in the underbelly.
TexasGolfBum is offline   Reply With Quote
Old 05-20-2018, 08:42 PM   #4
Canadian Member
Mine are accessible, just below the coroplast belly cover. That's why this is an option for me if it works well. I'm just wondering if anybody here has tried this.
I know there is a liquid drain valve lubricant that Thetford sells but this would be cheaper and you could re-do it as often as needed.
Old 05-20-2018, 08:46 PM   #5
This guy recommends canola oil.
Haven't tried it myself, but I intend to try it.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 06-05-2018, 12:07 PM   #6
Canadian Member
Old 06-05-2018, 12:21 PM   #7
yes, ... someone else here on the forum presented that idea I guess about three years ago, ... looked good to me, so I did the mod on our Micro Lite 25KS and have used it ever since, ... easy to do and very useful, ..... I only spray silicon into the slide, ...
fella10 is offline   Reply With Quote
Old 06-05-2018, 12:25 PM   #8
Prime Member
I've used this stuff.
https://www.amazon.com/RV-Drain-Valv...alve+lubricant
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 08-19-2018, 03:37 PM   #9
Canadian Member
Well, I was able to try this method this week to lubricate the black tank dump valve. The straw on my lithium spray lube can disappeared so I just used silicone spray lube inside and on the plunger. It does work better but not as good as new like I was hoping. I’ll try it again next dump and make sure I can use lithium spray lube. If that doesn’t get it operating like new I’ll just replace the valve. Fortunately my dump valves are below the coroplast underbelly cover so they’re easy to access.
Old 08-19-2018, 04:09 PM   #10
Thurman's Avatar
On some RV's the handle you see is connected to a cable which is connected to the actual valve located up under the under belly stuff. The cable is a wire housed within a tightly wound spring. This is where the problem is at times, the wire within the housing gets rusty. My previous TT has this happen and I had to remove the under belly covering which was like thin corrugated aluminum. Removing the cables, taking them apart, cleaning them and lubing them worked wonders. There was also an abundance of cable to each valve also, like six (6) feet of cable when there was only three (3) feet needed. I shortened the cables so that they were more of a straight run from the handle to the valve and all of that together made me happy.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
cat, manual, valve
