Old 07-02-2015, 10:53 PM   #1
Chopper911ed's Avatar
Lukewarm water.. Help please.
Barely warm water on 2016 vibe 312bhs. Got full hookups at campground and went to outside and turned switch to on an waited 1 hr an lukewarm water only. I did make sure there was water in tank before turning it on. Any suggestions???
2014 Ram 2500 6.4 Hemi
2016 Vibe 312BHS
Chopper911ed is offline   Reply With Quote
Old 07-02-2015, 11:24 PM   #2
bikendan's Avatar
Did the dealer show you the WH bypass valve.?
It's probably still in winterized mode.
That's why we recommend Camp Driveway.
So these things are discovered before you go camping.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-02-2015, 11:26 PM   #3
Nope
2016 Vibe 312BHS
Old 07-02-2015, 11:28 PM   #4
bikendan's Avatar
Originally Posted by Chopper911ed View Post
Nope
Then that's the first thing to check.
Old 07-02-2015, 11:47 PM   #5
crunchman12001's Avatar
X2, switch the valves by the water heater.
You will need to have the hot and cold valves open / parallel to the water lines and the center valve closed/perpendicular to the line.
crunchman
2015 F-250 FX4
Old 07-03-2015, 12:31 AM   #6
Engineer of Crazy Train
ChooChooMan74's Avatar
Make sure your outside shower is off at the handles and not at the shower head. That is a common place for mixing if both hot and cold are left on.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 07-03-2015, 12:39 AM   #7
bikendan's Avatar
that would've been my second suggestion if it wasn't the bypass valve.
Old 07-03-2015, 08:03 AM   #8
No outside shower . I just need to find the valves since they never showed us.
2016 Vibe 312BHS
Old 07-03-2015, 08:09 AM   #9
KyDan's Avatar
Go outside and find the water heater then go inside and imagine how
to access the back side of that.
Valves in question located on the inside/rear of the water heater tank.
Good Luck!
Old 07-03-2015, 08:14 AM   #10
Good Luck!
X2.......most of the time you can access the back of the water heater through a blank panel by removing a couple of screws.
crunchman
2015 F-250 FX4
water
