Old 12-11-2015, 09:46 PM   #11
MNtraveler's Avatar
Did you remove the water filter and check the filter container? You may find it with 1/2 water, 1/2 pink stuff. If so, dump it out (outside the MH!) and reinstall empty. Be sure to meticulously dry the threads that for some reason are hard to clear off and easy to freeze-crack. Some might say to put a little pink stuff in there but if there's no water....
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 12-12-2015, 07:52 AM   #12
Yup, dumped it out and added a sealed empty water bottle, to minimize the amount of RV antifreeze. Thanks.
Linda
LTRVing is offline   Reply With Quote
Old 12-12-2015, 08:07 AM   #13
Originally Posted by LTRVing View Post
Although a fair amount of anti-freeze went into the black tank, I added a bit more and some over the seal. Can't wait to get on the road again, as the song goes...
What (Pete the Plumber) said is a Separate Issue than the Black Tank,or Toilet! Do as he said,air or antifreeze! Youroo!!
winter, winterize
