Old 11-30-2015, 08:34 PM   #1
Maiden Voyage, Winterizing Check.
As first time RVers we just took our 2013 3170DS Sunseeker out for our maiden voyage, highway driving was smooth, averaged about 8 MPG. RV was winterized at pickup, hooked up at the campground, flushed all lines until pink was gone, took WH off bypass, installed anode rod, everything fired up fine, hot water, generator, frig, freezer, stove. Potty was broken in properly.
Dumped Black and Grey w/o problems, rinsing well between tanks. Had three great days, crisp evenings were enjoyable in a warm RV with a beverage of choice.
Once home, expecting freezing temps, we opened low point (little drainage, since we ran off city water and didn't fill FW tank, HW tank was bypassed and drained at the campground) used 30 PSI compressed air to clear all water sources in the RV, connected suction tube to water pump, drew about 2 gallons of RV antifreeze through all water taps and allowed them to drain a bit into the traps. Poured a bit more into each trap and toilet. Cleaned up excess antifreeze in sinks and bowls. Not anticipating travel for a month or so, did I miss anything winterizing? Should I leave a little antifreeze sitting in the toilet?
Did I mention that this is a hoot, can't wait for the next trip. BTW thanks to all for all the info and responses prior to this trip.
Linda
LTRVing is offline   Reply With Quote
Old 11-30-2015, 08:39 PM   #2
TLAK's Avatar
Did you get the outside shower? Broke mine once, now I take the head off and put it inside.
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 11-30-2015, 08:42 PM   #3
Yup, got the outside shower. Thanks.
Linda
Old 11-30-2015, 08:46 PM   #4
heavynlori's Avatar
We leave a small amount of pink stuff in toilet to keep seal wet
heavynlori is online now   Reply With Quote
Old 11-30-2015, 08:46 PM   #5
heavynlori's Avatar
Do you have washer hookup? That needs winterized too if so
Old 11-30-2015, 08:51 PM   #6
No dish washer, ice maker, clothes washer. Also, we pulled the water filter and put a empty sealed water bottle in there to take up space. Put an inch or so of antifreeze over the potty seal. Thanks.
Linda
Old 12-01-2015, 03:42 PM   #7
oldsmasma's Avatar
If your fridge is unplugged remember to leave the doors open a bit to avoid any mold issues. Oh and don't forget to cross the calendar days off until your next camping trip!
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
oldsmasma is offline   Reply With Quote
Old 12-01-2015, 09:22 PM   #8
HerveVR's Avatar
We also put Fabric softener Sheets, like Bounce, here and there to keep unwanted friends away; they apparently don't like the odour.
We place them under the mattress, cushions, in the drawers, under the seats, etc.
Let air circulation possible to avoid condensation.
That is how we take care of our 2012 Lexington 265.
HerveVR is offline   Reply With Quote
Old 12-02-2015, 05:22 PM   #9
Whatever
PeterThePlumber's Avatar
Wow, the only other thing I can think of is to either blow out the black tank flush with air or charge it with RV antifreeze.
I am only responsible for what I say, not what you may hear.
PeterThePlumber is offline   Reply With Quote
Old 12-02-2015, 08:13 PM   #10
Although a fair amount of anti-freeze went into the black tank, I added a bit more and some over the seal. Can't wait to get on the road again, as the song goes...
Linda
winter, winterize
