Old 10-29-2007, 01:53 PM   #11
Originally Posted by LESLIEandVIC View Post
K i got an adjustable one now, im seeing 2 different PSIs on this thread tho, 40 and 55 ? whats safe whats not also
is this PSI with the water already running inside the trailer or with everything off? whats the best way to go with that?
Right now i have it set to 53 PSI with the water off (inside trailer of course) but it drops down to 42 - 43 when the water is on.
Mine came(watts) factory set for 50 psi and that's where I left it. Make sure you ALWAYS us it. We were camped at a place with 160psi!!! Yup, they warned you at check in about the pressure. And they were right. Bent my little ole pressure gauge that reads up to 100psi like it was a pretzel. Now I have one that reads 160psi. Did a number on my cheapie hose, I now have hoses that are good up to about 150psi. Reason my hose took a hit was I like to put my whole house regulator up by the tt not at the water pedistal. Less chance of it growing legs while we are away.
Paul B
2001 Excursion PSD
2000 CRV Honda
2006 829GRSS Flagstaff TT
2004 Twin 2000i Hondas'
Paul B is offline   Reply With Quote
Old 10-29-2007, 05:55 PM   #12
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Paul B
That's just crazy! That's higher than we use in most fire hoses...
Could make for an interesting shower!
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 10-30-2007, 08:45 AM   #13
Crazy but very true!! Replaced my cork screwed psi gauge with one that goes to 160psi and it went right up to the max.
As I said, at least they did warn everybody of the extreme pressures.
Paul B
2001 Excursion PSD
2000 CRV Honda
Old 10-30-2007, 05:40 PM   #14
welshman599's Avatar
Send a message via MSN to welshman599
160!!!! Wait, I bet they have this sign "We are not liable for any....."
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 10-31-2007, 06:25 AM   #15
You may also want to look at the lenght and diameter of your hose. The shorter the better and the thicker the better.
Bill
2006 Hemi Ram Quad Cab 4x4
2005 Cherokee 28A+
Bduece is offline   Reply With Quote
Old 10-31-2007, 07:31 PM   #16
Quite a personal subject, really.
Old 07-08-2011, 11:22 PM   #17
I know this is a very old thread, but remember the shower scene from "club med"?
Chewy is offline   Reply With Quote
Old 07-09-2011, 07:09 AM   #18
DAISY BOYKIN's Avatar
Accepted standard water pressure-----
The accepted standard for water pressure is 40-65 PSI. Most city water pressure is around 50-60 PSI. But campgrounds can vary it is on a well from--- well just about any pressure they can get away with.
As stated, purchase a good adjustable pressure regulator with a gage, set your pressure at 55 PSI. At this pressure you will be covered for your RV.
I was in a CG in Forsyth, GA that the pressure was 95 PSI, it not only blew the hose out of the connection on the side of my RV (brand new) but also ruptured a new fresh hose. I did not have a regulator at the time,
but you can bet your bippy I have an adjustable regulator now.
The workers at the CG stated, "we get our water from the city of Forsyth"
RV ers are always complaining about too much water pressure.
Well DUH, install a regulator at the water entrance to the park BUBBA!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
