Old 02-17-2014, 11:41 PM   #11
Rrickim63's Avatar
Sorry. Responding to text messages
Sent from my LG-LS720 using Forest River Forums mobile app
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 02-18-2014, 04:33 PM   #12
jonrjen's Avatar
Originally Posted by Kaadk View Post
This is probably a lousy idea, at least I thought it was when I heard it, but I'm going to throw it out there.
I was talking to another camper once who said he always suffered low pressure in his 5th wheel. To fix it, he routed his city water connection into his fresh water and ran everything off the freshwater pump instead. Unfortunately that's as much as I got out of the conversation so I never did find out how he dealt with all the problems I see with that approach, such as the overflow tube, excess wear on the pump, etc...
On past RVs, we have on occasion been hooked up to city water that did not deliver a good shower pressure. And would turn on the water pump which would then add water and pressure from our fresh water holding tank delivering a good strong shower pressure.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 02-18-2014, 04:47 PM   #13
Kaadk's Avatar
I'm ok with running both. What I thought was a bad idea was re-routing his citywater connection into his freshwater tank.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 02-18-2014, 06:01 PM   #14
jonrjen's Avatar
I agree with you!!
2013 Wildcat 353LS
Old 02-18-2014, 06:22 PM   #15
I'm ok with running both. What I thought was a bad idea was re-routing his city water connection into his freshwater tank.
Maybe he just FILLED the FW tank from city water. If you have the anti-freeze connection, you can hook your city water hose to that, then open the valve to the pump and back fill your FW tank. You need to be careful and not over-pressurize your FW tank. Make sure you have adequate venting available. He can probably do this once a day. Then he just runs his normal pump from the FW tank. Only issue I really see is wear and tear on the pump.
2011 Traverse LT, 3.6L, FWD
pressure, water
