Old 03-10-2015, 07:07 PM   #11
I'm not sure what your referring to. Are you referring to this in my basement? The couplers are also under the sink. The tube from the sink to the shelve seems a bit damp but i don't see water.
gr8white is offline   Reply With Quote
Old 03-10-2015, 07:17 PM   #12
Those look like hot & cold water lines, I'd tighten them. Mine has a hot & cold and had 2 white braided hoses with the vent/vacuum breaker at the ends which is removed and ran the input directly to the black tank and eliminated 10' of hose and the leaking vent/vacuum breaker. Looks like yours is different.
Old 03-13-2015, 10:23 PM   #13
Love RVing
We use a mixture of vinegar and baking soda to dissolve the hair routinely.
burse is offline   Reply With Quote
Old 03-21-2015, 02:54 PM   #14
I will try that mixture today. I read that elsewhere as well. The plunger didnt work.
Old 03-21-2015, 03:13 PM   #15
toslow's Avatar
if you can buy pipe cleaners, from the smoke shop you might be able to stick it down and pull some of the hair back out.
haven a blast
toslow is offline   Reply With Quote
Old 03-21-2015, 03:19 PM   #16
The baking soda/vinegar mixture fixed most of the problem. It still doesn't drain as quick as it should but another dose of the mixture should fix it. I cant figure out for the life of me how to get the top off over the drain. I don't see a screw and when I turn it it doesn't come off.
Old 03-21-2015, 03:26 PM   #17
toslow's Avatar
if it has a P-TRAP the pipe cleaners will work if they reach deep enough
haven a blast
Old 03-21-2015, 03:31 PM   #18
Ford Idaho's Avatar
You may find them at Walmart or Walgreens.
20" Drain Clog Remover- Quick and Painless Slow-Drain Relief - Bathroom Sink And Tub Drain Strainers - Amazon.com
I have seen some at Ace Hardware but the cost .more
Old 03-21-2015, 05:20 PM   #19
Left Coast
Mean not to offend, but a trip to barber shop and more often under the spout.
drain
