Old 08-27-2012, 01:43 AM   #1
My propane water heat will only light and relight with the door open.
I have a 2012 Coachmen Catalina 40TBS with a gas/electric hot water system. Almost from day one, the propane system would not light without problem or relight without boom. When the outside door of the unit is open, it will run without incident or problem. Close the outside door and "click, click, click BOOM", no light. A "technician" checked it out twice (the last time when I wasn't present) and had no problems because the door was open (the way he left it when it was checked last). I am talking to them again tomorrow, but would sure like to know if this problem has happened to anyone else and how to fix it if I get the run around.
waynenorth44001 is offline   Reply With Quote
Old 08-27-2012, 03:23 AM   #2
Sounds like to me its not getting enough air when door is closed have you checked the gas tube to see that it is clear spiders like to built webs in there just a thought
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 08-27-2012, 10:22 AM   #3
Triguy's Avatar
First, did the dealer check for leaks?
Assuming no leaks, then look at Suburban operations manual linked to below (You did not say if you have a Suburban or Atwood water heater, but from your description it sounds like it could be the Suburban SW6DE (Suburban, Water Heater, 6 gl, Direct Spark, Electric)).
Water Heater - Suburban Operation Page 22 has a troubleshooting guide that is helpful. This is the regular user manual for that model for your reference -- Water Heater - Suburban 6 Gallon User Guide
Both the gas has to run freely and the spark has to spark correctly and at the right time. When done correctly, there will be an audible pop as it lights, but not a boom. The boom indicates that either the gas or the spark or both are a problem. If the spark is not right or is not located correctly in the flow of gas then too much gas builds up and ignites with a boom. I guess this only happens with yours when the door is closed allowing the gas to build up faster.
These are things the dealer really should have checked for when they looked at it for you. But, if you want to do it yourself ...
Clean the burner tube. A common problem as mentioned by chevy02 is a partially blocked tube from a small spider web. I don't know why, but spiders love to make webs in these things. I have had this issue before and blowing out the tube or cleaning it some other way usually corrects the issue.
If that doesn't work, then try to adjust the spark gap between the two electrodes. The gap should be about 1/8" (see page 22). There are two probes so measure the gap. You can bend the non-ceramic carefully. Do not break the probes.
Also, its possible the probes are not aligned correctly within the flow of gas. Reposition the electrode assembly so that it is in the flow of gas. IIRC (because I am not in front of my camper) you can loosen the electrode assembly mounting screw and shift the assembly slightly.
Let us know how it goes. Good luck! And, Welcome to the forum!!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-28-2012, 07:45 AM   #4
Herk7769's Avatar
I would begin my search; here.
HAM CALLSIGN - KC3FFW
Old 11-17-2012, 04:47 PM   #5
We have a brand new Coachmen Catalina and this is our first time to take it out and the water heater will not stay working. No spiders, disappointed
Cnjstrong is offline   Reply With Quote
Old 11-17-2012, 07:02 PM   #6
Iggy's Avatar
Take to dealer under warrantee or are you waiting for it to catch fire?
Come on....
2012 Georgetown XL - 378TS 66K + miles
Old 11-17-2012, 08:37 PM   #7
VinceU's Avatar
Welcome to the Forum, good place to get help! However you must tell us more.. Like what is it not doing. Is it on elec or on gas you have plenty of fuel etc. Think your note got lost in the thread you posted to! In other words its buried under another heading of the same type problem. Post the make and model and what its doing wrong and someone will help you.
