Old 02-21-2014, 06:25 PM   #11
davel1971's Avatar
Originally Posted by Rmack View Post
Is there a procedure for cleaning the rod? Can it be removed?
with no pressure on system, just unthread it from side of tank. Flush tank out while its out. You will be surprised what comes out of there.
David & Lynn
Old 02-21-2014, 06:42 PM   #12
After compiling everybody's kind advice, here's what must have happened, and what I'm going to do:
Pulling my plumbing dry by negligently leaving the faucet on after the tank ran out stirred up funkage somewhere. Maybe my water tank, since it comes out of the cold side, maybe my hot water tank, maybe both.
My filter was not installed until after a couple of trips, so lots of hard water went threw the plumbing at first. Or, the filter could be somehow failing lately. Or both
I'm going to have the whole system flushed, including both hot water and cold water tanks, the filter replaced, and the anode rod replaced on the hot tank.
I'll tell the DH that it probably was time to do it anyway to justify the expense of throwing money at the problem.
Thanks, everyone. I would have worried myself crazy on my own trying to figure this out.
Ray and Carol, boxer Duke and his daughter Duchess
2013 FR Rockwood Mini Lite 2104 with Murphy bed.
4 WD Nissan Xterra with supercharger and tow package.
2 Yamaha EF2000iS generators
Rmack is offline   Reply With Quote
Old 02-21-2014, 08:36 PM   #13
I reviewed all of this, and was thinking of how the calcium or whatever deposits could be coming from my cold water faucet.
I had turned on both hot and cold knobs at first. Later, I determined that hot (though not hot at the time) was flowing better than cold. by a lot. The cold was the line I sucked dry. It would have been releasing air against the solid hot line flow.
What if the disturbed hot water debris got pushed down the cold water channel in the mixing area of the bathtub faucet. It would explain the restricted flow, and the white chunks coming out when I only had the cold open.
The particles probably did come from the hot water side.
Old 02-21-2014, 08:58 PM   #14
Originally Posted by dannyabear View Post
Probably crud from the anode rod, thats what uou're discribing.
Correct,the (Hot Water) is After the Filter! Youroo!!
Old 02-21-2014, 09:07 PM   #15
Since you prob.dont Winterize your W/Heater,you should remove the anode rod and drain & clean it,per need by water type & usage. Youroo!!
Old 02-21-2014, 10:29 PM   #16
Herk7769's Avatar
Anode bits and calcium nodules can also enter your cold water lines if you use the low point drains to drain your water heater.
Always isolate the water heater using the bypass valves before removing the anode rod for inspection and draining the water heater from the anode hole.
This prevents that crud from entering the COLD water pipes (the low pipe in the water heater). Running the water empty allowed that crud to enter the cold water pipes. Once you repressurized the system the incoming cold water pushed that crud up to the faucets.
HAM CALLSIGN - KC3FFW
Old 02-21-2014, 10:35 PM   #17
mark0224's Avatar
Hard water scale was probably in the pump and when it went dry it flaked off then when you added water it moved through the lines. Take the screens off the faucets run some water through the lines and it should flush out.
mark0224 is offline   Reply With Quote
water
