Old 09-02-2014, 01:49 PM   #11
Arefbee's Avatar
We don't have any fancy flush system But I have my own method.
First, make sure to use plenty of water every time you flush. A quick flush clears the bowl but the solids can build up to a mountain without enough water.
Before going home, do a normal dump. After dumping, pump a couple of gallons into the waste tanks from the fresh water.
Immediately after getting home, dump into a bucket and dispose of the stuff in the septic tank top pipe. The trip should have oscillated the left over mess to the tank low point and broken it down a bit.
So far, so good.
Oh, by the way, spray everything with bleach when done.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 09-02-2014, 05:26 PM   #12
Canadian Member
itat's Avatar
Arefbee, there is another video on Youtube by the same guy with the clear tank setup where he tests the ice cube theory. It does help some but not a lot. So, just having water in the black tank for the trip home won't get the remaining solids out. I use the GEO method hoping it will at least prevent solids from sticking to the tank so much that my wand won't loosen it. There are no guarantees unless you can use a fire hose to rinse it out or you just don't use the toilet.
Old 09-02-2014, 08:13 PM   #13
Arefbee's Avatar
I add Calgon powder as well. We're not totally geo yet since we seem to have a lifetime supply of the blue stuff. Not sure how we got 4 bottles of it.
Frankly, long as it dumps out successfully, not concerned about it being sparkling clean. It is what it is.
2013 - 15
black, black tank, drain, tank, water
