08-30-2014, 06:36 PM
Myth - Black Tank Drains Clear Water Means it is Empty
I see many posts that advise using a clear elbow when draining the black tank and to flush until the liquid runs clear. Supposedly this means the tank has been emptied. I subscribed to this theory for years.
However my current TT has proved this to be a myth, at least most of the time. I had issues with the black tank not reading empty, even with clear draining water. On the last two dumps, I sat next to the elbow and watched as I flushed the tank. I would notice that often when the liquid ran clear, the flow was reduced. So I would close the gate valve for a few minutes and reopen. Sure enough, a big chunk of TP would come out and then more waste. It appears that TP would get right in front of the drain and actually filter the water so it appears clear.
The only way to make sure the tank is empty, at least for me, is to make sure the flow is clear AND strong. I have found that it takes a good 20-30 minutes to properly flush and empty a black tank.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
08-30-2014, 07:02 PM
I'd say the elbow isn't so much to see the liquid run clear as it is just to see what's going on.
2011 Traverse LT, 3.6L, FWD
08-30-2014, 07:32 PM
My clear section is to see the liquid run clear. However; after initial dump I close the dump valve and fill the tank and then dump again. Takes about 20 min for the tank to refill from the cleanout port. If not clear after first time then I do it again till liquid runs clear. I know there is a warning to not close the valve with the cleanout active but that's hog wash. The indicator light will show an empty tank after this procedure and the tank will be as clean as can be. There are several on line videos showing how to empty a black water tank.
Canadian Member
Teamfour, have a look at these videos...
08-30-2014, 07:38 PM
Plain Old Member
We never just use the flush system alone. Usually when they're new, we time filling the tank with our water system at home, which is about the only place we actually flush and dump the tanks. Our procedure for dumping tanks is by innitially dumping the tank with the flush system running, close the dump valve and time filling the tank, dump, repeat etc etc. We do use the clear fitting as well. By using the flush system alone until it runs clear (tank valve always open), it will not get everything in the tank. By partially filling the tank each time, there is a better chance for the volume of water to carry the solids better. Some disagree with this method as they say you can overflow the tank. True, but, if you've done like me, and figured out the timing of the fill, and you DON'T get distracted and walk off, this method works very well.
I've played with these flush nozzles, several different kinds, and I assure you it will not clean that tank very well. They only hit parts of the tank, and you will in fact see clear water, yet still have stuff in the tank. I have installed additional flush nozzles in tanks before which proved a shade more effective.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
08-30-2014, 07:43 PM
Those videos helped me develop my process and only prove what I stated. Thanks.
Lee and Anne
08-30-2014, 07:49 PM
For me, running the tank flush does not thoroughly clean the tank by itself. I heard somewhere the suggestion to close the drain valve while the tank flush is running to fill the tank (the manufacturer says DON'T do this!). This fill/dump will bring with it much debris that the original dump and the flushing process missed.
A couple trips ago I had full hookups and plenty of time. I performed the above (dump/flush/fill/dump). I then (for no particular reason) ran the flush with the valve open again and went for a bike ride. The ride ended up much longer than expected and the tank flush had been running over an hour by the time I returned. The water coming from the tank was clear and strong. I then for some reason closed the valve for a 2nd fill/dump, and to my surprise...a bunch more debris passed. I then was on a mission...went for a 3rd fill/dump, and it finally ran clear...as near as I could tell.
In short, using the tank flush to fill/dump the tank at least once and maybe twice is the only/best way to get a clean tank...IMO.
edit...sorry for the redundancy...I type slow!
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
08-30-2014, 09:05 PM
I think after watching the one video I will keep using Camco 40074 Flexible Swivel Stik Rv Tank Rinser because it can reach from one end of the tank to the other and get the most out.
Think about things before you do them make life easier not harder.
09-02-2014, 01:30 PM
I agree. From watching that video with the clear tank, you can really see that even a full tank of water does not really to that much to move the solids out. You need to spray directly in the tank and try to break it up into smaller pieces and get it to flush out.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
09-02-2014, 01:49 PM
We don't have any fancy flush system But I have my own method.
First, make sure to use plenty of water every time you flush. A quick flush clears the bowl but the solids can build up to a mountain without enough water.
Before going home, do a normal dump. After dumping, pump a couple of gallons into the waste tanks from the fresh water.
Immediately after getting home, dump into a bucket and dispose of the stuff in the septic tank top pipe. The trip should have oscillated the left over mess to the tank low point and broken it down a bit.
So far, so good.
Oh, by the way, spray everything with bleach when done.
2011 PrimeTime Tracer 2600rls
09-02-2014, 05:26 PM
Canadian Member
Arefbee, there is another video on Youtube by the same guy with the clear tank setup where he tests the ice cube theory. It does help some but not a lot. So, just having water in the black tank for the trip home won't get the remaining solids out. I use the GEO method hoping it will at least prevent solids from sticking to the tank so much that my wand won't loosen it. There are no guarantees unless you can use a fire hose to rinse it out or you just don't use the toilet.
09-02-2014, 08:13 PM
I add Calgon powder as well. We're not totally geo yet since we seem to have a lifetime supply of the blue stuff. Not sure how we got 4 bottles of it.
Frankly, long as it dumps out successfully, not concerned about it being sparkling clean. It is what it is.
