Originally Posted by Zoom
Follow the directions in the P1 manual but add a couple of steps. Drain the HW tank and put the plug back in. Configure the P1 to the City Water and blow out all of the lines with a compressor including the low point drains. After that take out the HW plug and make sure all water is purged from the system. If you follow the rest of the P1 manual steps (including placing some of the valves in the 45 degree position) and add your antifreeze you should be OK. Also don't forget to turn around the screen filter in the water input to allow for the antifreeze to pump into the system. Btw the red valve is the HW bypass.
Didn't see anything about turning the screen filter around. Appears that the antifreeze made it to all the fixtures, low point drains, and water filter housing. Any idea why the screen filter should be turned around. Thanks Again for your feedback.
