Old 07-09-2012, 06:26 AM   #1
need a new hot water heater
I am getting orange colored water thru my hot water valves.... I am assuming that the inner lining in my suburban water heater has cracked and I am getting rust from the outer metal tank.
I see they have tank-less instant heaters now....is this a better way to go? Its 1/3 of the cost of a new 6gal heater.
Our camper is seasonal now....only used April thru Oct.
Brad & Melissa
2002 Ford Expedition 4X4 4.6 ltr
1999 ForestRiver Flagstaff 829BHS
braddaddy is offline   Reply With Quote
Old 07-09-2012, 06:48 AM   #2
mgauldin's Avatar
Have you replaced your anode? This would cause rusty water if it has gone out.
The 17 day, 4800 mile trip to Yellowstone National Park was one to remember.
mgauldin is offline   Reply With Quote
Old 07-09-2012, 06:49 AM   #3
From what I've seen on this forum I would NOT even consider a tankless water heater. Have no experience with them, but it seems like everyone that has one is wishing they had the tank type.
Old 07-09-2012, 06:50 AM   #4
Triguy's Avatar
There has been some discussion about tankless water heaters and the issues some owners are wrestling with. Here's a list of threads in FRF that describe the issues.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 07-09-2012, 08:37 AM   #5
I tried to replace the anode....it was sooooo tight...when I finally got it to turn I felt it hit on the inside like it was L shapped..... wouldnt continue to turn.... so I tightened it back up.
Brad & Melissa
Old 07-09-2012, 08:58 AM   #6
As bad as it may sound, you need to get the anode out regardless of how much trouble it is to do. It may have so much crud built up on it that it will take some persistance and patience to remove it, but it has to be replaced and the tank cleaned with a water probe of some sort to get the remaining loose crud out.
Sorry to be the bearer of bad news.
Old 07-09-2012, 09:04 AM   #7
TURBS's Avatar
I'm with Dunnnc.
Keep trying to turn in and out .
Have you ever had it out?
How do you drain water in the winter?
