Old 05-22-2014, 05:51 PM   #1
hrlyguy2's Avatar
Need help ....
Just flushed out my antifreeze and see its pouring water out of the out side spray hose connection.
I'm leaving tomorrow.And of course this happens the day before.
Should of checked it before but no time .
Any help to let me fix would be appreciated
Thank you
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 05-22-2014, 05:53 PM   #2
Fulltime family RVer
Which part of it? One of my handles worked itself loose due to improper winterization. I had to take apart the cold to see how it was supposed to go together. All of the pieces were there- it just had loosened itself magically (1 of 3 connections the did it).
ependydad is online now   Reply With Quote
Old 05-22-2014, 06:27 PM   #3
hrlyguy2's Avatar
It's the one by the entry door.no handles on that side.
Old 05-22-2014, 06:41 PM   #4
hrlyguy2's Avatar
this is where the water is pouring out
Old 05-23-2014, 09:22 PM   #5
Jimmerinwi's Avatar
Need help ....
Could it be the little dooflinky (sorry forgot the name) that's at the end of the outlet is stuck open? Maybe push on it and see if it'll reseat itself.
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 05-23-2014, 09:46 PM   #6
Batts-toy's Avatar
'the little dooflinky' or 'backflow preventer' or 'check valve'. If you can't get it unstuck and want to fix later you can go the a hardware store or RV center and get a hose quick connect unit that has a built in check valve.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 05-23-2014, 09:53 PM   #7
VinceU's Avatar
Originally Posted by hrlyguy2 View Post
There is a small one way valve behind that hose gasket, should be a screen as well. Remove the gasket and screen and see if the valve disc and stem will push in maybe 1/4" or less with a weak spring trying to push it out again. If its not working maybe a RV dealer where you are heading can sell you a city water connection. They aren't expensive and very easy to change, the screws on the outside and a threaded hose or pipe connection when you free it from the RV side.
Be sure to use sealant when you put the flange back on.
Old 05-24-2014, 07:06 AM   #8
hrlyguy2's Avatar
Thanks guys.
Got it fixed.Had to replace the whole thing.
Cut off the rope caulking around the base
Take out 4 screws
Pull the whole cone piece out unscrew from hose fitting and put it back together
The cone and water connection is all 1 piece
Old 05-24-2014, 08:03 AM   #9
Batts-toy's Avatar
Way to go, now get out there and have camping fun galore.
