Old 09-02-2014, 05:19 PM   #1
Kungfu01's Avatar
Need help figuring out a hook up my home septic system
It just so happens where I park my TT is right next to the cleanout for my septic system. I did not load pictures but if it is necessary I can.
The cap to the tank is about 1 foot below grade and is beveled concrete. Approximate diameter is about 12 inches.
I need help figuring out what a good way to install a PVC hookup so I can tie in just like at the campsite.
I can't seem to come up with anything that will be sturdy and permanent but will also allow for routine cleanings of the septic system every few years.
Any ideas?
- 2015.5 Salem 30QBSS Show Stopper
- Previous 1999 Skamper Lite by Thor
Kungfu01 is offline   Reply With Quote
Old 09-02-2014, 11:15 PM   #2
I would make a cheap mold with wood and have a pice of right-size PVC in the middle that you can put your dump hose into, then use quick create to make that into a concrete cap that can sit on top of your clean out port for your septic tank. Should be cheap, heavy enough to not move on its own, and will be manageable enough to move when needed.
Cheers,
Army Jedi
2015 V-Lite 30WRLIKS (soon), 2005 F150 FX4
1974 Wife, hottie model with all the options
2013 German Wirehaired Pointer (Holmes)
2013 Wirehaired Pointing Griffon (Watson)
army_jedi is offline   Reply With Quote
Old 09-02-2014, 11:22 PM   #3
Iwannacamp's Avatar
Prolly a 4" PVC male adapter
A piece of 4" pipe(to make height)
4" female adapter
4" threaded plug
This should allow your sewer hose to fit in FA once you take out plug.
I assume your fittings are 4". That's the normal size....and I assume you are using the slinky hose.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 09-02-2014, 11:26 PM   #4
Plain Old Member
We've had RV hookups in both of our shops (50/30 power, water and sewer). On those, I set the pipe just a shade below grade (for spillage) and beveled the concrete down to it. Wish I had pictures here. However before that we used the clean outs on the sewer system. Ours already had a 4" fitting with female thread and a cap / plug, so screwing in the Rhino fitting worked out fine.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 09-03-2014, 05:23 PM   #5
How do you connect it to the septic tank though? My tank cap is similar except buried about a foot below the surface.(no beveled concrete)
2011 Forester 3171DS Pic
SOLD!
New Rig: 2018 Tiffin 32SA
torino421 is offline   Reply With Quote
Old 09-03-2014, 05:32 PM   #6
If your tank top is pvc like mine, you could just cut an accurate hole and glue a pvc threaded connector to it so your slinky connector would screw into it.
